[Mapserver-users] History for 3.6.4 ?
Yewondwossen Assefa
assefa at dmsolutions.ca
Fri Jan 17 10:18:01 EST 2003
This is a multi-part message in MIME format.
--------------BF0BE9FC0F7C8388431B076E
Content-Type: text/plain; charset=iso-8859-1
Content-Transfer-Encoding: 8bit
Attached is HISTORY.txt with the changes. This file is also available in
the mapserver cvs repository.
Later,
Guillaume SUEUR wrote:
> Hi there,
> Where can I find the description of the changes from 3.6.3 to 3.6.4 ?
> Thx
> Guillaume SUEUR
> Ingénieur développement SIG
> KHI2 - BVA
> 25bis Avenue Marcel Dassault
> 31505 TOULOUSE CEDEX 5
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
Content-Type: text/plain; charset=us-ascii;
name="HISTORY.TXT"
Content-Transfer-Encoding: 7bit
Content-Disposition: inline;
filename="HISTORY.TXT"
MapServer Revision History
This is a human-readable revision history which will attempt to document
required changes for users to migrate from one version of MapServer to the
next. Developers are strongly encouraged to document their changes and
their impacts on the users here. (Please add the most recent changes to
the top of the list.)
For a complete change history, please see the CVS log comments. A copy of
the CVS logs is updated daily at the following URL:
http://www2.dmsolutions.ca/mapserver/dl/mapserver_changelog.txt
Version 3.6.4 (2003-01-08)
- Use LD instead of CC to refer to linker program name in the Makefile to
help dealing with GCC 3.x issues (doesn't resolve the issue completely)
- Added missing MS_LAYER_CIRCLE and MS_CC constants in PHP MapScript
- Fixed bad memory corruption bug with WMS SRS parameter value mapwms.c
(Thanks to Ed M. for finding it)
- Added version 3.7's mappostgis.c
- minor bug fixes
- lots of help if you make a mistake
- more functionality
- Fixed problem in space-delimited wms_srs metadata with WMS client mode
where the last SRS in the string was never used even if it would have
been a best match. Causing unnecessary WMS reprojections in several cases.
- Fixed configure script to produce an error if --with-gdal does not point
to a valid gdal-config file.
Version 3.6.3 (2002-10-07)
- Fixed problem with numeric labels with OGR's STYLEITEM AUTO (bug 185)
- PHP MapScript: fixed set() method on all object types for parameters
of type float and string. The param value was not forced to the right
type and this could lead to unexpected values being set or crashes.
- Fixed bug 174 - improperly terminated string buffer in msWMSException()
- Fixed problem with 'gcc undef' appearing in the mapscript/php3/Makefile
on FreeBSD. Also added --enable-internal-ld-detect configure switch to
force use of an internal configure macro to detect ld command and args
in case the default doesn't work (this is for mapscript/php3/Makefile only)
- Fixed potential crash with WMS GML query output (missing msInitSHape() in
msGMLWriteQuery())
- Fixed Windows-specific problem where WMS capabilities were always returned
as 1.0.0 even if 1.1.0 was requested
Version 3.6.2 (2002-07-08)
- Added msTokenizeMap() in MapScript (and via 'mapserv -t test.map')
- Added map->setFontSet()
- Fixed Windows-specific problem with PHP MapScript ms_newMapObj("")
called with empty filename.
- Fixed problem with double 'gcc' appearing in mapscript/php3/Makefile on
some systems.
Version 3.6.1 (2002-06-20)
- Fixed a performance problem in msImageFilledPolygon() (bug 162)
3.6.0 was up to 50% slower than 3.5 rendering polygons, and now
3.6.1 is up to 10-20% faster than 3.5.
- Removed obsolete PHP3 stuff in README files and configure scripts.
- Fixed color problem with crosshair in reference map.
- Fixed an issue with "LOCATION TINY" being output in legend label objects.
- Postgis bug 165: fix dont_force() to allow for POINT shapes
- Make sure inline symbols (symbols defined in the mapfile) are saved
when msSaveMap() is called. They used to be lost.
Version 3.6.0 (2002-05-28)
- No change since 3.6.0-beta2
Version 3.6.0-beta2 (2002-05-23)
- A few fixes.
- PostGIS: Added Sean Gillies <sgillies at i3.com>'s patch for "using unique
<column name>". Added "using SRID=#" to specify a spatial reference
for an arbitrary sql query.
- WMS Capabilities XML: Return grouped/ungrouped layers in an order closer
to the natural mapfile order (bug 154)
- Integrated patch from Tim Mackey to support ROSA applet parameters via
mapserv CGI, see:
http://mapserver.gis.umn.edu/wilma/mapserver-users/0011/msg00077.html
Version 3.6.0-beta1 (2002-04-30)
- MapScript: qitem and qstring params added to layer->queryByAttribute().
Instead of being driven by the layer's FILTER/FILTERITEM, the query by
attribute is now driven by the values passed via qitem,qstring, and the
layer's FILTER/FILTERITEM are ignored.
- Symbol and MapFile changes:
ANTIALIAS and FILLED keywords now take a boolean (TRUE/FALSE) argument
i.e. ANTIALIAS becomes ANTIALIAS TRUE
and FILLED becomes FILLED TRUE
- Reference Map:
Added options to show a different marker when the reference box becomes
too small. See the mapfile reference docs for more details on the new
reference object parameters (MARKER, MARKERSIZE, MAXBOXSIZE, MINBOXSIZE)
- Added MINSCALE/MAXSCALE at the CLASS level.
- Support for tiled OGR datasets.
- PHP 4.1.2 and 4.2.0 support for PHP MapScript.
- Added LAYER TRANSPARENCY, value between 1-100
- Fixes to the SWIG interface for clean Java build.
- New HTML legend templates for CGI and MapScript. See HTML-Legend-HOWTO.
- WMS server now supports query results using HTML query templates instead
of just plain/text.
- Added support functions for thread safety (--with-thread). Still not
100% thread-safe.
Version 3.5.0 (2002-12-18)
- No Revision history before version 3.5
$Id: HISTORY.TXT,v 1.3.2.26 2003/01/08 19:06:59 dan Exp $
--------------BF0BE9FC0F7C8388431B076E--
