[Mapserver-users] Odd Error
Dylan Keon
keon at nacse.org
Mon Jan 20 20:19:58 EST 2003
Jeff Berry wrote:
> I have a lakes polygon layer that draws just fine at large scales. However,
> if I zoom out to the entire extent of the dataset I get the following error:
> Warning: MapServer Error in msDrawShape(): Only polygon shapes can be drawn
> using a POLYGON layer definition.
> This happens with a couple other polygon layers as well, when I zoom out to
> a point where a lot of polygon features are displayed in the current extent.
> What is causing this?
Could those layers contain unclosed polygons? This is just a wild guess
since I don't know how MapServer handles that type of situation, but
perhaps the large scale views were successful because you happened to be
displaying small regions where all polygons were closed. Then, when
zoomed to full extent, MapServer throws the error when trying to render
the unclosed polygons (?)
If you have ArcInfo at your disposal you could try converting your
shapefiles to coverages, running CLEAN to build polygon topology, and
converting back to shapefiles.
--Dylan
Dylan Keon
GIS/Database Research Specialist
Northwest Alliance for Computational
Science and Engineering (NACSE)
Oregon State University
Corvallis, OR 97331
keon at nacse.org (541) 737-6608
