[Mapserver-users] Wierd PostGIS Layer Error - msPOSTGISLayerWhichShapes()
Benjamin Wragg
bwragg at tpg.com.au
Wed Jan 22 15:41:52 EST 2003
Hi All,
I've just fired PostGIS up and I'm getting the following error when I
use the draw() method of the mapObj:
Warning: MapServer Error in msPOSTGISLayerWhichShapes(): prep_DB:Error
executing POSTGIS DECLARE statement (0.6 failed - retried 0.5 and it
failed too). DECLARE mycursor BINARY CURSOR FOR SELECT
asbinary(force_collection(force_2d()),'NDR'),OID::text from WHERE &&
setSRID('BOX3D(-180 -45,180 225)'::BOX3D, find_srid('','','') ) in
C:\MAB\Dev\mapscripttest\test.php on line 4
>From what I've learnt so far, it seems that this query is missing the
geometry columns. Any ideas why?
Heres the map file I'm using:
NAME TEST
EXTENT -180 -90 180 90
SIZE 400 300
STATUS ON
UNITS DD
IMAGECOLOR 255 255 255
SYMBOLSET symbols.sym
WEB
MINSCALE 2000000
MAXSCALE 50000000
IMAGEPATH "c:/mab/dev/temp/"
IMAGEURL "/ms_tmp/"
END
LAYER
CONNECTIONTYPE postgis
NAME "testpoints"
# Connect to a remote spatial database
CONNECTION "user=user password=password dbname=dbname
host=localhost"
# Get the lines from the 'geom' column of the 'roads' table
DATA "the_geom FROM testpoints"
STATUS default
TYPE POINT
CLASS
COLOR 255 0 0
END
END
END
I've tried all different configurations in the map file but I don't
think this is the problem because the $map=ms_newMapObj('mapfile.map')
line of code is getting executed with no errors. Also the $map object
exists because I can print out some of the variables?
Any ideas?
Thanks,
Benjamin Wragg
