[Mapserver-users] mapscript seems to be fubar
pkishor_98 <pkishor at geoanalytics.com>
Fri Jan 24 00:21:12 EST 2003
Steve L, Lowell, others,
I seem to have fubar-ed my perfectly working copy of mapscript, and
can't figure out how to set it right.
I rebuilt mapserver 3.6.4. Straight, no frills --
./configure --with-jpeg --with-gd=../gd-1.8.4 --with-png=/usr/local/lib
Got the usualy slew of messages and warnings and what-not, and then
mapserv is built just fine --
[lucknow:~/Projects/mapserver/mapserver-3.6.4] pkishor% ./mapserv -v
MapServer version 3.6.4 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
SUPPORTS=TTF INPUT=TIFF INPUT=EPPL7 INPUT=JPEG INPUT=SHAPEFILE
Then I do the perl Makefile.PL, make, sudo make install dance, and
mapscript.pm gets built and installed in its correct place. But
nothing works with perl. Trying out the simplest dump.pl, I get
[lucknow:mapscript/perl/examples] pkishor% ./dump.pl -file=~/dap.shp
Can't locate object method "new" via package "shapefileObj" at
./dump.pl line 18.
and so on. When I turn diagnostics on, I get --
-file=~/Sites/palatine/data/dap.shp
./dump.pl line
19 (#1)
(F) You said to do (or require, or use) a file that couldn't be
found. Perl looks for the file in all the locations mentioned in @INC,
unless the file name included the full path to the file. Perhaps
you need
to set the PERL5LIB or PERL5OPT environment variable to say where
the extra
library is, or maybe the script needs to add the library name to
@INC. Or
maybe you just misspelled the name of the file. See perlfunc/require
and lib.
Uncaught exception from user code:
./dump.pl line 19.
I know that mapscript.pm is in my @INC which is --
/System/Library/Perl/darwin
/Library/Perl
/Library/Perl
/Network/Library/Perl/darwin
because make install put it there --
[lucknow:mapserver-3.6.4/mapscript/perl] pkishor% sudo make install
Password:
Installing /Library/Perl/darwin/auto/mapscript/mapscript.bs
Installing /Library/Perl/darwin/auto/mapscript/mapscript.bundle
Files found in blib/arch: installing files in blib/lib into
architecture dependent library tree
Installing /Library/Perl/darwin/mapscript.pm
Writing /Library/Perl/darwin/auto/mapscript/.packlist
Appending installation info to /System/Library/Perl/darwin/perllocal.pod
I am at a dead end. Any suggestions as to where I should begin looking
