[Mapserver-users] How to Draw Annotation Layer Last
    Dan Barron
    dbarron at ddive.com
    Thu Jan 23 21:51:29 PST 2003
--=====================_25681046==.ALT
Content-Type: text/plain; charset="iso-8859-1"; format=flowed
Content-Transfer-Encoding: quoted-printable
For future reference for anyone who may have a similar problem, here is the=
=20
path I took to resolve the problem in drawing the annotation layer last.
I finally took a step back on this problem and simplified my map file and=20
my php/mapscript code and was successful in getting the layer to appear on=
=20
top of all other layers.  I also upgraded to MapServer 3.6.4, php/mapscript=
=20
3.6, and PHP 4.3.0 so as the have the current stable versions to work with.
With the help of the folks on the list - here's a couple observations that=
=20
seemed worth sharing.  If these are well known to everyone, then my=20
apologies up front.
- The position of the annotation layer object in the map file had no=20
effect.  Once working properly, the annotation layer FEATURE TEXT was drawn=
=20
last and therefore visible on top of all other layers in all cases whether=
=20
the annotation layer object was first or last in the map file.
- In php/mapscript, the method $map->drawLabelCache($image) was needed only=
=20
when the annotation layer object STATUS was set to OFF in the map file and=
=20
you dynamically retrieved the layer object in php/mapscript and set the=20
layer object STATUS ON then called $layer->draw($image).  Otherwise, if the=
=20
STATUS was set to ON or DEFAULT, the FEATURE TEXT would appear successfully.
I've included the simplified map file and php/mapscript code used to get my=
=20
bearings on this.
Dan
# mapnavigatorTEST.map
name mapnavigatorTEST
size 720 360
status ON
extent -120.0 0.0 -10.0 70.0
units DD
shapepath "data"
imagetype PNG
transparent off
fontset "./fonts/font.list"
symbolset "./symbols/symbols.list"
PROJECTION
  "proj=3Dlatlong"
  "ellps=3DGRS80"
END
WEB
   imagepath "c:/bin/jboss-2.4.0_tomcat-3.2.3/tomcat/webapps/tmp/"
   imageurl "/tmp/"
END
# Start of scalebar
SCALEBAR
   label
     color 50 50 150
     size tiny
   end
   style 0
   size 200 4
   color 50 50 150
   outlinecolor 0 0 0
   units miles
   intervals 3
   transparent false
   status off
END
# REFERENCE map
REFERENCE
   image ""
   size 100 100
   extent -190 -95 190 95
   color -1 -1 -1
   outlinecolor 255 50 50
END
# LAYER definitions
# Credits
LAYER
  NAME credits
  STATUS off
  TRANSFORM false
  TYPE annotation
  FEATURE
    points 1 10 end
    text '=A9 www.destinationdive.com'
  END
  CLASS
    NAME credits
    LABEL
      type truetype
      font verdana
      size 8
      antialias true
      color 51 51 51
      position UR
      backgroundcolor 255 255 255
      buffer 2
    END
  END
END
# main base map layer
LAYER
     name Country
     type POLYGON
     status on
     data 'country'
     minscale 26000010
     class
       name Country
          outlinecolor 204 204 204
       color 255 255 204
     end
END
# NORTH AMERICA
LAYER
   NAME canada
   TYPE POLYGON
   STATUS ON
   GROUP 'north_america'
   DATA 'north_america/canada/ponet_poly_poly'
   MAXSCALE 26000000
   class
     name canada
     color 255 255 204
   END
END
LAYER
   NAME mexico
   TYPE POLYGON
   STATUS ON
   DATA 'north_america/mexico/ponet_poly_poly'
   MAXSCALE 26000000
   CLASS
     name mexico
     color 255 255 204
   END
END
# USA
LAYER
   NAME states
   TYPE POLYGON
   STATUS ON
   DATA 'north_america/usa/statesp020'
   MAXSCALE 26000000
   CLASS
     name states
     color 255 255 204
   END
END
END
// simple-map-test.php
<?php
$mapPath=3D"c:/bin/jboss-2.4.0_tomcat-3.2.3/tomcat/webapps/mapserver3.5/";
$mapFile=3D"mapNavigator-test.map";
$map =3D ms_newMapObj($mapPath.$mapFile);
$image=3D$map->draw();
$credits =3D $map->getLayerByName("credits");
$credits->set("status", MS_ON );
$credits->draw( $image );
$map->drawLabelCache($image);
$image_url_PNG=3D$image->saveWebImage(MS_PNG,1,1,0);
$image->free();
<img src=3D"<?php echo $image_url_PNG?>" border=3D"1"=
 style=3D"background-color:=20
#99ccff;" alt=3D"">
Content-Type: text/html; charset="iso-8859-1"
<html>
<body>
<tt>For future reference for anyone who may have a similar problem, here
is the path I took to resolve the problem in drawing the annotation layer
last.<br><br>
on top of all other layers.  I also upgraded to MapServer 3.6.4,
php/mapscript 3.6, and PHP 4.3.0 so as the have the current stable
versions to work with.<br><br>
that seemed worth sharing.  If these are well known to everyone,
then my apologies up front.<br><br>
was drawn last and therefore visible on top of all other layers in all
cases whether the annotation layer object was first or last in the map
file.<br><br>
only when the annotation layer object STATUS was set to OFF in the map
file and you dynamically retrieved the layer object in php/mapscript and
set the layer object STATUS ON then called $layer->draw($image).
Otherwise, if the STATUS was set to ON or DEFAULT, the FEATURE TEXT would
appear successfully.<br><br>
my bearings on this.<br><br>
Dan<br><br>
~~~~~~~~~~<br>
# mapnavigatorTEST.map<br>
~~~~~~~~~~<br><br>
name mapnavigatorTEST<br>
size 720 360<br>
status ON<br>
extent -120.0 0.0 -10.0 70.0<br>
units DD<br>
shapepath "data"<br>
imagetype PNG<br>
transparent off<br>
fontset "./fonts/font.list"<br>
symbolset "./symbols/symbols.list"<br><br>
PROJECTION<br>
 "proj=3Dlatlong"<br>
 "ellps=3DGRS80"<br>
END<br><br>
WEB<br>
  imagepath
"c:/bin/jboss-2.4.0_tomcat-3.2.3/tomcat/webapps/tmp/"<br>
  imageurl "/tmp/"<br>
END<br><br>
#~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~<br>
# Start of scalebar<br>
SCALEBAR<br>
  label<br>
    color 50 50 150<br>
    size tiny<br>
  end<br>
  style 0<br>
  size 200 4<br>
  color 50 50 150<br>
  outlinecolor 0 0 0<br>
  units miles<br>
  intervals 3<br>
  transparent false<br>
  status off<br>
END<br><br>
# REFERENCE map<br>
REFERENCE<br>
  image ""<br>
  size 100 100<br>
  extent -190 -95 190 95<br>
  color -1 -1 -1 <br>
  outlinecolor 255 50 50<br>
END<br><br>
# LAYER definitions<br>
#~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~<br><br>
#~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~<br>
# Credits<br>
#~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~<br><br>
LAYER<br>
 NAME credits<br>
 STATUS off<br>
 TRANSFORM false<br>
 TYPE annotation<br>
 FEATURE<br>
   points 1 10 end  <br>
   text '=A9
<a href=3D"http://www.destinationdive.com/" eudora=3D"autourl">www.destinati=
ondive.com</a>'
<br>
 END<br>
 CLASS<br>
   NAME credits<br>
   LABEL<br>
     type truetype<br>
     font verdana<br>
     size 8<br>
     antialias true<br>
     color 51 51 51 <br>
     position UR <br>
     backgroundcolor 255 255 255<br>
     buffer 2<br>
   END<br>
 END<br>
END<br><br>
# main base map layer <br>
LAYER<br>
    name Country<br>
    type POLYGON<br>
    status on<br>
    data 'country'<br>
    minscale 26000010<br>
    class<br>
      name Country<br>
<x-tab>        </x-tab>
outlinecolor 204 204 204<br>
      color 255 255 204<br>
    end<br>
END<br><br>
# NORTH AMERICA<br>
LAYER<br>
  NAME canada<br>
  TYPE POLYGON<br>
  STATUS ON<br>
  GROUP 'north_america'<br>
  DATA 'north_america/canada/ponet_poly_poly'<br>
  MAXSCALE 26000000<br>
  class<br>
    name canada<br>
  END<br>
END<br><br>
LAYER<br>
  NAME mexico<br>
  TYPE POLYGON<br>
  STATUS ON<br>
  DATA 'north_america/mexico/ponet_poly_poly'<br>
  CLASS<br>
    name mexico<br>
  END<br>
END<br><br>
# USA<br>
LAYER<br>
  NAME states<br>
  TYPE POLYGON<br>
  STATUS ON<br>
  DATA 'north_america/usa/statesp020'<br>
  CLASS<br>
    name states<br>
  END<br>
END<br><br>
END<br><br>
~~~~~<br>
// simple-map-test.php<br>
~~~~~<br><br>
<?php <br><br>
$mapPath=3D"c:/bin/jboss-2.4.0_tomcat-3.2.3/tomcat/webapps/mapserver3.5=
/";<br>
$mapFile=3D"mapNavigator-test.map";<br><br>
$map =3D ms_newMapObj($mapPath.$mapFile);<br>
$image=3D$map->draw();<br><br>
$credits =3D $map->getLayerByName("credits");<br>
$credits->set("status", MS_ON );<br>
$credits->draw( $image );<br><br>
$map->drawLabelCache($image);<br>
$image_url_PNG=3D$image->saveWebImage(MS_PNG,1,1,0);<br><br>
$image->free();<br><br>
?><br><br>
<img src=3D"<?php echo $image_url_PNG?>"=
 border=3D"1" style=3D"background-color: #99ccff;"=
 alt=3D""><br><br>
</body>
</html>
--=====================_25681046==.ALT--
More information about the MapServer-users
