[Mapserver-users] Arabic label
Daniel Penninck
squale_666 at hotmail.com
Fri Jan 24 00:24:50 PST 2003
Steve,
As I fear, this didn't solve the problem. I still have the same 'garbage'
text instead of correct arabic text.
Could you suggest me another solution?
Thanks.
>From: woodbri at swoodbridge.com
>Reply-To: woodbri at swoodbridge.com
>To: mapserver-users at lists.gis.umn.edu, "Daniel Penninck"
><squale_666 at hotmail.com>
>Subject: Re: [Mapserver-users] Arabic label
>Date: Thu, 23 Jan 2003 20:47:36 -0500
>Daniel,
>I found the link you need to get the titus unicode true type font.
>They have an arabic font, look under the unicode link on the right to
>get started:
>http://titus.fkidg1.uni-frankfurt.de/indexe.htm
>-Steve W.
>On 23 Jan 2003 at 18:25, woodbri at swoodbridge.com wrote:
> > Daniel,
> > You will need to get a true type font that will render the arabic
> > characters correctly before it will look correct. I found one
> > searching the web, but I am in the process of moving everything to a
> > new system and I can't find anything at the moment. But try a google
> > search for something like "arabic true type font download" should get
> > you pretty close.
> > -Steve W.
> > On 23 Jan 2003 at 22:42, Daniel Penninck wrote:
> > > Hi,
> > > I would like to know how to display arabic label in my mapserver
> > > test application.
> > > I have streets's names encoded in arabic: character code is
> > > ISO-8859-6. Example of label value in the db: ÔÇÑÚ ÇáÏáÊÇ and I am
> > > sure this value can be display in arabic.
> > > I want to see them as arabic label in the map, but it doesn't work:
> > > I was no-sens label instead!
> > > Can Someone help?
> > > Thanks,
> > > Daniel.
> > > PS:
> > > value in db:
> > > ÔÇÑÚ ÇáÏáÊÇ
> > > arabic label:
> > > ﺎﺘﻓﺪﻓﺍ
> > > ﻍﺭﺎﺷ
> > > _________________________________________________________________
> > > Hotmail: votre e-mail gratuit ! http://www.fr.msn.be/hotmail
> > > Mapserver-users mailing list
> > > Mapserver-users at lists.gis.umn.edu
> > > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
More information about the MapServer-users
