[Mapserver-users] legend.exe
Steve Lime
steve.lime at dnr.state.mn.us
Fri Jan 24 14:09:59 EST 2003
I'll start with the obvious. Are layers on? Do classes have names?
Without those a legend can't be built...
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> "John McCue" <jmccue at geovue.com> 01/24/03 08:07AM >>>
I am having a problem getting legend.exe from version 3.6.3 to create
a
legend. The map file I am using works fine. The LEGEND section I am
using
in the map file is:
LEGEND
KEYSIZE 18 12
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
END
STATUS ON
END
When I run legend.exe, I just get a white image that is 33 pixels wide
by 5
high whether I set a gif or png as the output file.
Thanks!
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
