[Mapserver-users] Raster geotiff turns background yellow
randy james
rjames57 at yahoo.com
Mon Jan 27 12:52:38 EST 2003
Hi
I do not have a high speed internet available, the
GeoTIFF file is 176MB in size. Too large to email.
Cheers
Randy
--- Ed McNierney <ed at topozone.com> wrote:
> Randy -
> Is it possible for you to make the GeoTIFF
> available? Thanks.
> - Ed
> Ed McNierney
> President and Chief Mapmaker
> TopoZone.com / Maps a la carte, Inc.
> 73 Princeton Street, Suite 305
> North Chelmsford, MA 01863
> ed at topozone.com
> (978) 251-4242
> -----Original Message-----
> From: randy james [mailto:rjames57 at yahoo.com]
> Sent: Monday, January 27, 2003 12:35 PM
> To: Mapserver Users
> Subject: Re: [Mapserver-users] Raster geotiff turns
> background yellow
> Hi List
> I checked the geotiff file in the GIMP and it did
> not
> have any yellow in the image. But than i checked the
> image created by Mapserver and it has the yellow
> background on it. Soo i assume that the cgi is
> creating the yellow. Also i noticed that the polygon
> layer loaded before the geotiff has changed to the
> grayscale color of the geotiff.
> I am sending the rendered imaged created by
> mapserver
> cgi for review.
> Cheers
> Randy
> --- woodbri at swoodbridge.com wrote:
> > Randy,
> > I assume that the color change is taking place
> when
> > view in a
> > browser? Have you tried to view it in an image
> > viewer?
> > Sometimes the browser pre allocates an bunch of
> > colors and when you
> > load the geotiff, it does not have enough slots in
> > the color lookup
> > table and has to assign the additional colors to
> > existing ones. Some
> > software is better at this than others, but it is
> > typically the
> > reason why your get the type of color change you
> > described.
> > -Steve W.
> > On 24 Jan 2003 at 14:51, randy james wrote:
> > > Hi list
> > > Has anyone experienced problems with a geotiff
> > file
> > > making the image background turn yellow? (or any
> > > color)
> > > The orthophoto (geotiff) that causes the problem
> > is my
> > > fist attempt at projecting a raster on the fly.
> I
> > have
> > > tried importing the ortho into GRASS and than
> > > exporting it again, but it did not make a
> > difference.
> > > The gdalinfo utility output is quite large for
> the
> > > ortho causing the problem, but once its exported
> > from
> > > GRASS it is the same as the orthos that work (i
> > think)
> > > I'm wondering if its something to to with
> > projecting a
> > > raster or is it the file format. I will read
> and
> > try
> > > the gdal_translate utility next i guess
> > > MapServer version 3.6.4 OUTPUT=PNG OUTPUT=JPEG
> > > OUTPUT=WBMP SUPPORTS=PROJ SUPPORTS=TTF
> > > SUPPORTS=WMS_SERVER INPUT EPPL7 INPUT=JPEG
> > > INPUT=POSTGIS INPUT=GDAL INPUT=SHAPEFILE
> > > Cheers
> > > Randy
> __________________________________________________
> > > Do you Yahoo!?
> > > Yahoo! Mail Plus - Powerful. Affordable. Sign up
> > now.
> > > http://mailplus.yahoo.com
> > > Mapserver-users mailing list
> > > Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> Do you Yahoo!?
> now.
Do you Yahoo!?
Yahoo! Mail Plus - Powerful. Affordable. Sign up now.
