[Mapserver-users] Program to clean up *gif files
Yewondwossen Assefa
assefa at dmsolutions.ca
Mon Jan 27 17:03:40 EST 2003
The defualt value is set to 1 hour but can be modifued on the command line :
deltmpfiles <directory> [hour]
"Martin, Daniel" wrote:
> I tried the DM Solutions exe. It works as advertised. It obviously takes
> into consideration the age of the file, and only deletes things that are
> older than some amount of time. That's excellent, considering problems
> might occur if you delete a map while someone is actively downloading the
> image.
> For curiosity's sake, could Daniel or anyone else at DM Solutions say what
> that amount of time is?
> Thanks,
> Dan
> -----Original Message-----
> From: Dylan Keon [mailto:keon at nacse.org]
> Sent: Monday, January 27, 2003 2:30 PM
> To: John Rubin
> Cc: mapserver-users at lists.gis.umn.edu
> Subject: Re: [Mapserver-users] Program to clean up *gif files
> John Rubin wrote:
> > Can anyone recommend a program to automatically erase gif files created by
> mapserver in the ../tmp directory? We are looking for a program for both
> windows and Unix.
> For Unix, it's best to run a shell script through the cron utility.
> There is more info at http://mapserver.gis.umn.edu/doc36/manage.html
> For Windows, DM Solutions has a .exe file available at
> http://www2.dmsolutions.on.ca/webtools/dl/deltmpfiles.zip
> --Dylan
> Dylan Keon
> GIS/Database Research Specialist
> Northwest Alliance for Computational
> Science and Engineering (NACSE)
> Oregon State University
> Corvallis, OR 97331
> keon at nacse.org (541) 737-6608
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
