[Mapserver-users] ECW files
Richard Greenwood
rich at greenwoodmap.com
Mon Jan 27 21:27:54 EST 2003
--=======748E4F2B=======
Content-Type: text/plain; x-avg-checked=avg-ok-53426139; charset=us-ascii; format=flowed
Content-Transfer-Encoding: 8bit
At 11:42 AM 1/28/2003 +1030, you wrote:
>Greetings all,
>I'd like to use an ecw file in a Mapserver application and need some
>clues.
>I'm using Mapserver 3.6 binary on a Windows NT box. It's all running
>happily, though all files are presented unprojected.
>Firstly, http://www.remotesensing.org/gdal/frmt_ecw.html doco says
>maximum ecw filesize is 500MB, and the dataset is larger than that.
>Any clues on software that can uncompress, clip and recompress?
http://www.ermapper.com/ has free uncompress and compress tools. The viewer
(which does the uncompression) can write out a world file. GRASS is my
choice for clipping or tiling. And I think there are some performance
advantages in using a tiled set of images even when using sophisticated
compression like ECW or MrSID.
>Secondly, doco says certain SDK dll's are required and suggests
>location in the 'same directory as the GDAL DLL'. I found the SDK
>library, but I can't find the GDAL DLL on my machine. Where does the
>GDAL come from?
>Thirdly, I'm worried about projection. The ecw is in UTM Zone 53
>South GDA94 (=WGS84 horizontally) and I want to project to Albers,
>already configured. I this object adequate:
Be sure you set Albers in the main section of your map file (outside of a
layer definition). You might consider reprojecting from UTM to Albers when
you tile.
>LAYER
> NAME "mtlofty_ecw"
> DATA "MtLoftyRanges.ecw"
> TYPE RASTER
> STATUS ON
> PROJECTION
> "proj=utm"
> "ellps=WGS84"
> "datum=WGS84"
> "units=m"
> "zone=53"
> "south"
> "no_defs"
> END
>END
>Regards,
>Lyndon Z
>Adelaide, Australia
>_______________________________________________
>Mapserver-users mailing list
>Mapserver-users at lists.gis.umn.edu
>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Richard W. Greenwood, PLS
(307) 733-0203
Rich at GreenwoodMap.com
www.GreenwoodMap.com
--=======748E4F2B=======--
