Antwort: Re: [Mapserver-users] switching layers when zooming
Gunter.Rieth at stadt.mainz.de
Tue Jan 28 08:20:17 EST 2003
This is a multipart message in MIME format.
------=_NextPartTM-000-3ab0aa26-329f-11d7-bc9e-0090274d4ab2
Content-Type: multipart/alternative;
boundary="=_alternative 004943AFC1256CBC_="
--=_alternative 004943AFC1256CBC_=
Content-Type: text/plain; charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Here you can see one example still working , but you have to watch out the =
path and filename in the TILEINDEX file.
STATUS ON only because I switch the layers as a group from the html file
# Start of layer definitions
LAYER
NAME "Stadtplan"
DATA "stadtplan/gesamtplan.tif"
GROUP Stadtplan
TYPE RASTER
STATUS ON
MINSCALE 85000
MAXSCALE 150000=20
=20
# TRANSPARENCY 20
END
LAYER
NAME "stadtp=5F2x2"
TYPE RASTER
GROUP Stadtplan
TILEINDEX "stadtplan/index=5F2x2.shp"
TILEITEM "Location"
STATUS ON
MINSCALE 500
MAXSCALE 85000=20
TRANSPARENCY 75
END
Gunter Rieth
KDZ Mainz
Hechtsheimer Stra=DFe 35
55131 Mainz
Tel: 06131 - 12 - 3557
Fax: 06131 - 12 - 2267
eMail: mailto:Gunter.Rieth at stadt.mainz.de
intern: Gunter Rieth/Dez1/Mainz
Oliver Wesp <wesp at gdv.com>
Gesendet von: mapserver-users-admin at lists.gis.umn.edu
28.01.2003 12:15
=20
An: Agneta Schick <schick at sdac.hannover.bgr.de>
Kopie: mapserver-users at lists.gis.umn.edu
Thema: Re: [Mapserver-users] switching layers when zooming
Maybe the identical layer name causes this effect. Maybe it's better to=20
use the group option. Should be something like this:
LAYER
NAME relief=5Fhighscale
GROUP relief
END
LAYER
NAME relief=5Flowscale
GROUP relief
END
This way you have unique layer names, but you still can handle it as one=20
layer in your application via the group name.
Agneta Schick schrieb:
> Hello,
>=20
> As long as I was only using only one layer I thought I knew what I was=20
doing.
>=20
> Apparently not... I want to show a layer (1:1000000) and after zooming
> below 1:250000 switch to a different layer.
> My solution is define two layers with the same name but different=20
MINSCALE,
> MAXSCALE:
> LAYER
> NAME relief
> DATA graul0.tif
> TYPE RASTER
> MAXSCALE 5000000
> MINSCALE 250000
> STATUS DEFAULT
> END
> LAYER
> NAME relief
> TILEINDEX index200.shp
> TILEITEM "dtk200"
> TYPE RASTER
> MAXSCALE 250000
> STATUS DEFAULT
> END
> MapScript:
> my $layer =3D $map->getLayerByName('relief');
> $layer->draw($map, $img);=20
>=20
> I expected Mapserver to interpret $map->{scale} and show the appropriate
> map. My result: after zooming below 250000 my layer is empty.
> Each if the two layers are ok as a single layer and I've checked the=20
contents of=20
> $map->{scale} so that's not the problem.
> Is my whole assumption wrong?
>=20
> Thank you for your help.
> Agneta Schick
>=20
>=20
>=20
> Agneta Schick
>=20
> Bundesanstalt fuer Geowissenschaften und Rohstoffe
> Federal Institute for Geosciences and Natural Resources
> Stilleweg 2
> D- 30655 Hannover Tel.: +49 511 643 3136
> GERMANY FAX.: +49 511 643 3663
>=20
> schick at sdac.hannover.bgr.de http://www.seismologie.bgr.de
>=20
>=20
>=20
>=20
> =5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
>=20
>=20
>=20
--=20
Dipl.-Geogr. Oliver Wesp
Gesellschaft f=FCr geografische Datenverarbeitung
Binger Strasse 49-51
D-55218 Ingelheim
fon: +49 6132 714818
fax: +49 6132 714828
http: www.gdv.com
=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=
Content-Type: text/html; charset="iso-8859-1"
<br><font size=3D2 face=3D"sans-serif">Here you can see one example still w=
orking , but you have to watch out the path and filename in the TILEI=
NDEX file.</font>
<br>
<br><font size=3D2 face=3D"sans-serif">STATUS ON only because I switch the =
layers as a group from the html file</font>
<br>
<br><font size=3D2 face=3D"sans-serif"># Start of layer definitions</font>
<br><font size=3D2 face=3D"sans-serif">#</font>
<br><font size=3D2 face=3D"sans-serif">LAYER</font>
<br><font size=3D2 face=3D"sans-serif"> NAME "Stadtplan"</f=
ont>
<br><font size=3D2 face=3D"sans-serif"> DATA "stadtplan/ge=
samtplan.tif"</font>
<br><font size=3D2 face=3D"sans-serif"> GROUP Stadtplan</font>
<br><font size=3D2 face=3D"sans-serif"> TYPE RASTER</font>
<br><font size=3D2 face=3D"sans-serif"> STATUS ON</font>
<br><font size=3D2 face=3D"sans-serif"> MINSCALE 85000</font>
<br><font size=3D2 face=3D"sans-serif"> MAXSCALE 150000 </font>
<br><font size=3D2 face=3D"sans-serif"> </font>
<br><font size=3D2 face=3D"sans-serif"># TRANSPARENCY 20</font>
<br><font size=3D2 face=3D"sans-serif">END</font>
<br><font size=3D2 face=3D"sans-serif"> NAME "stadtp=5F2x2"=
</font>
<br><font size=3D2 face=3D"sans-serif"> TYPE RASTER</fon=
t>
<br><font size=3D2 face=3D"sans-serif"> GROUP Stadtplan<=
/font>
<br><font size=3D2 face=3D"sans-serif"> TILEINDEX "=
stadtplan/index=5F2x2.shp"</font>
<br><font size=3D2 face=3D"sans-serif"> TILEITEM "L=
ocation"</font>
<br><font size=3D2 face=3D"sans-serif"> MINSCALE 500</font>
<br><font size=3D2 face=3D"sans-serif"> MAXSCALE 85000 </font>
<br><font size=3D2 face=3D"sans-serif"> TRANSPARENCY 75</=
font>
<br>
<br><font size=3D2 face=3D"sans-serif"> END</font>
<br>
<br>
<br><font size=3D2 face=3D"sans-serif">Gunter Rieth<br>
<br>
KDZ Mainz<br>
Hechtsheimer Stra=DFe 35<br>
55131 Mainz<br>
<br>
Tel: 06131 - 12 - 3557<br>
Fax: 06131 - 12 - 2267<br>
eMail: mailto:Gunter.Rieth at stadt.mainz.de<br>
intern: Gunter Rieth/Dez1/Mainz</font>
<br>
<br>
<br>
<table width=3D100%>
<tr valign=3Dtop>
<td>
<td><font size=3D1 face=3D"sans-serif"><b>Oliver Wesp <wesp at gdv.com><=
/b></font>
<br><font size=3D1 face=3D"sans-serif">Gesendet von: mapserver-users-admin@=
lists.gis.umn.edu</font>
<p><font size=3D1 face=3D"sans-serif">28.01.2003 12:15</font>
<br>
<td><font size=3D1 face=3D"Arial"> </font>
<br><font size=3D1 face=3D"sans-serif"> An: &nbs=
p; Agneta Schick <schick at sdac.hannover.bgr.de></f=
ont>
<br><font size=3D1 face=3D"sans-serif"> Kopie: &=
nbsp; mapserver-users at lists.gis.umn.edu</font>
<br><font size=3D1 face=3D"sans-serif"> Thema: &=
nbsp; Re: [Mapserver-users] switching layers when zoomi=
ng</font></table>
<br>
<br>
<br><font size=3D2 face=3D"Courier New">Maybe the identical layer name caus=
es this effect. Maybe it's better to <br>
use the group option. Should be something like this:<br>
<br>
LAYER<br>
NAME relief=5Fhighscale<br>
GROUP relief<br>
.<br>
.<br>
.<br>
END<br>
<br>
LAYER<br>
NAME relief=5Flowscale<br>
GROUP relief<br>
.<br>
.<br>
.<br>
END<br>
<br>
This way you have unique layer names, but you still can handle it as one <b=
r>
layer in your application via the group name.<br>
<br>
Agneta Schick schrieb:<br>
> Hello,<br>
> <br>
doing.<br>
> <br>
> Apparently not... I want to show a layer (1:1000000) and after zooming=
<br>
> below 1:250000 switch to a different layer.<br>
> My solution is define two layers with the same name but different MINS=
CALE,<br>
> MAXSCALE:<br>
> ...<br>
> LAYER<br>
> NAME relief<br>
> DATA graul0.tif<br>
> TYPE RASTER<br>
> MAXSCALE 5000000<br>
> MINSCALE 250000<br>
> STATUS DEFAULT<br>
> END<br>
> LAYER<br>
> NAME relief<br>
> TILEINDEX index200.shp<br>
> TILEITEM "dtk200"<br>
> TYPE RASTER<br>
> MAXSCALE 250000<br>
> STATUS DEFAULT<br>
> END<br>
> ...<br>
> MapScript:<br>
> my $layer =3D $map->getLayerByName('relief');<br>
> $layer->draw($map, $img); <br>
> <br>
> I expected Mapserver to interpret $map->{scale} and show the approp=
riate<br>
> map. My result: after zooming below 250000 my layer is empty.<br>
> Each if the two layers are ok as a single layer and I've checked the c=
ontents of <br>
> $map->{scale} so that's not the problem.<br>
> Is my whole assumption wrong?<br>
> <br>
> Thank you for your help.<br>
> Agneta Schick<br>
> <br>
> <br>
~~~~~~~<br>
> Agneta Schick<br>
> <br>
> Bundesanstalt fuer Geowissenschaften und Rohstoffe<br>
> Federal Institute for Geosciences and Natural Resources<=
br>
> Stilleweg 2<br>
> D- 30655 Hannover &nb=
sp; Tel.: +49 511 643 3136<br>
> GERMANY =
FAX.: +49 511 643 3663<br>
> <br>
> schick at sdac.hannover.bgr.de =
http://www.seismologie.bgr.de<br>
~~~~~~~<br>
> <br>
> <br>
> <br>
=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F<br>
> Mapserver-users mailing list<br>
> Mapserver-users at lists.gis.umn.edu<br>
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users<br>
> <br>
> <br>
> <br>
<br>
<br>
-- <br>
Dipl.-Geogr. Oliver Wesp<br>
Gesellschaft f=FCr geografische Datenverarbeitung<br>
Binger Strasse 49-51<br>
D-55218 Ingelheim<br>
fon: +49 6132 714818<br>
fax: +49 6132 714828<br>
http: www.gdv.com<br>
<br>
</font>
<br>
<br>
--=_alternative 004943AFC1256CBC_=--
------=_NextPartTM-000-3ab0aa26-329f-11d7-bc9e-0090274d4ab2--
