[Mapserver-users] Smoothing NEXRAD imagery
Frank Warmerdam
warmerdam at pobox.com
Tue Jan 28 13:10:17 EST 2003
Daryl Herzmann wrote:
> I have been working on generating maps of current NEXRAD (Weather
> Service RARAR) imagery and overlaying observations. This is currently
> working great, except the pixelation that occurs at very close range.
> Does anyone know how to implement an automatic TIFF smoothing algorithm at
> close ranges?
> Here is a page with an example of what happens to the NEXRAD image at
> close ranges... The pixelation at 25km is not that bad and will probably
> be what I live with for the final app.
Daryl,
If you are using MapServer 3.7 from CVS there is a LoadGDALImage() function
in mapdrawgdal.c that is responsible for most imagery loads from GDAL. It
would be relatively easy to add a processing option to the map file that
would direct this function to load oversampled imagery with some sort of
smoothing - nearest neighbour or cubic convolution for instance.
If you are feeling ambitious go ahead and take a crack at it. The processing
arguments are generic all your changes would be in this one function.
The special case to watch for would be when src_xsize > dst_xsize or
src_ysize > dst_ysize. Just modify the code to loading into a data array
at the source resolution and resample appropriate into the output buffer.
I could do this, but I have little time available. Of course if you wanted
to pay I am sure someone would be happy to do it.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
