[Mapserver-users] Raster geotiff turns background yellow
Mark Cave-Ayland
mark.cave-ayland at webbased.co.uk
Tue Jan 28 14:01:17 EST 2003
Hi Randy,
I remember reading on the list that the GD v1 library used by mapserver
is limited to 256 colours - so maybe you are seeing a result of
mapserver attempting to reduce the colour depth of your image? Mapserver
3.7 uses GD v2 which may solve the problem.
Hope this helps,
Mark.
Mark Cave-Ayland
Webbased Ltd.
Tamar Science Park
Derriford
Plymouth
PL6 8BX
England
Tel: +44 (0)1752 764445
Fax: +44 (0)1752 764446
This email and any attachments are confidential to the intended
recipient and may also be privileged. If you are not the intended
recipient please delete it from your system and notify the sender. You
should not copy it or use it for any purpose nor disclose or distribute
its contents to any other person.
> -----Original Message-----
> From: randy james [mailto:rjames57 at yahoo.com]
> Sent: 28 January 2003 18:37
> To: Mapserver Users
> Subject: RE: [Mapserver-users] Raster geotiff turns background yellow
> Hi List
> Well i am still having the problem of a projected
> geotiff file changing the output of the mapserver cgi:
> the background turns yellow.
> I've tried
> importing and than exporting the image through GRASS
> tiff2bw to ensure the file is grayscale
> upgraded to the remotesensing site version of GDAL
> 1.1.7.1 from the Mandrake 8.2 version of 1.1.7.
> The geotiff image seems to be exactly like the ones
> that do not cause the problem.
> i am including a couple of files from the tmp
> directory, one where the background is yellow and one
> where it is not.
> does anyone know what next i should check?
> --- Ed McNierney <ed at topozone.com> wrote:
> > Randy -
> > Is it possible for you to make the GeoTIFF
> > available? Thanks.
> > - Ed
> > Ed McNierney
> > President and Chief Mapmaker
> > TopoZone.com / Maps a la carte, Inc.
> > 73 Princeton Street, Suite 305
> > North Chelmsford, MA 01863
> > ed at topozone.com
> > (978) 251-4242
> > Sent: Monday, January 27, 2003 12:35 PM
> > To: Mapserver Users
> > Subject: Re: [Mapserver-users] Raster geotiff turns
> > background yellow
> > Hi List
> > I checked the geotiff file in the GIMP and it did
> > not
> > have any yellow in the image. But than i checked the
> > image created by Mapserver and it has the yellow
> > background on it. Soo i assume that the cgi is
> > creating the yellow. Also i noticed that the polygon
> > layer loaded before the geotiff has changed to the
> > grayscale color of the geotiff.
> > I am sending the rendered imaged created by
> > mapserver
> > cgi for review.
> > Cheers
> > Randy
> > --- woodbri at swoodbridge.com wrote:
> > > Randy,
> > > I assume that the color change is taking place
> > when
> > > view in a
> > > browser? Have you tried to view it in an image
> > > viewer?
> > > Sometimes the browser pre allocates an bunch of
> > > colors and when you
> > > load the geotiff, it does not have enough slots in
> > > the color lookup
> > > table and has to assign the additional colors to
> > > existing ones. Some
> > > software is better at this than others, but it is
> > > typically the
> > > reason why your get the type of color change you
> > > described.
> > > -Steve W.
> > > On 24 Jan 2003 at 14:51, randy james wrote:
> > > > Hi list
> > > > Has anyone experienced problems with a geotiff
> > > file
> > > > making the image background turn yellow? (or any
> > > > color)
> > > > The orthophoto (geotiff) that causes the problem
> > > is my
> > > > fist attempt at projecting a raster on the fly.
> > I
> > > have
> > > > tried importing the ortho into GRASS and than
> > > > exporting it again, but it did not make a
> > > difference.
> > > > The gdalinfo utility output is quite large for
> > the
> > > > ortho causing the problem, but once its exported
> > > from
> > > > GRASS it is the same as the orthos that work (i
> > > think)
> > > > I'm wondering if its something to to with
> > > projecting a
> > > > raster or is it the file format. I will read
> > and
> > > try
> > > > the gdal_translate utility next i guess
> > > > MapServer version 3.6.4 OUTPUT=PNG OUTPUT=JPEG
> > > > OUTPUT=WBMP SUPPORTS=PROJ SUPPORTS=TTF
> > > > SUPPORTS=WMS_SERVER INPUT EPPL7 INPUT=JPEG
> > > > INPUT=POSTGIS INPUT=GDAL INPUT=SHAPEFILE
> > > > Cheers
> > > > Randy
> > __________________________________________________
> > > > Do you Yahoo!?
> > > > Yahoo! Mail Plus - Powerful. Affordable. Sign up
> > > now.
> > > > http://mailplus.yahoo.com
> > > > Mapserver-users mailing list
> > > > Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> > Do you Yahoo!?
> > now.
> Do you Yahoo!?
> Yahoo! Mail Plus - Powerful. Affordable. Sign up now.
