[Mapserver-users] Raster geotiff turns background yellow
randy james
rjames57 at yahoo.com
Wed Jan 29 17:50:03 EST 2003
Hi
To answer my own question: Rasters can be made
transparent using the TRANSPARENCY (0-100) tag.
I have tried with a raster layer loaded through
tileindex, but not with loading a raster the normal
way yet.
But i would hope that at some point i will be able to
load the orthophotos under the vectors without been
transparent, rather than on top of the vectors and
transparent.
--- randy james <rjames57 at yahoo.com> wrote:
> Hi
> Upgrading to 3.7 solved the problem of the tiff
> image
> turning the background yellow, but caused another
> problem:
> Any vector layer that is loaded on top if the tiff
> image now turns gray. When i load the vectors after
> the tiff nothing changes color at least, but i
> cannot
> see the vector layers.
> Can Raster layers be transparent?
> Cheers
> Randy
> --- Frank Warmerdam <warmerdam at pobox.com> wrote:
> > randy james wrote:
> > > Hi
> > > --- Ed McNierney <ed at topozone.com> wrote:
> > >>Randy -
> > >>Can you describe exactly what you did
> differently
> > >>between those two images?
> > > Well the difference is:
> > > the tif that does not work has: a 256 RGB,
> > > colorinterp=palette, is projected on the fly,
> and
> > is a
> > > newer version of an orthophoto.
> > > I have used tiff2bw and gdal_translate to make
> it
> > > grayscale, so i have a few versions of the file
> > (5),
> > > and all make the same error.
> > Randy,
> > I haven't been following this issue closely, but
> if
> > the problem occurs in
> > 3.7 and if you can prepare a small test case that
> > demonstrates the problem
> > just using "shp2img" then please file it in
> bugzilla
> > (attaching the small
> > sample map file and data file(s)) and assign to
> me.
> > Best regards,
> > I set the clouds in motion - turn up | Frank
> > Warmerdam, warmerdam at pobox.com
> > light and sound - activate the windows |
> > http://pobox.com/~warmerdam
> > and watch the world go round - Rush |
> Geospatial
> > Programmer for Rent
> __________________________________________________
> Do you Yahoo!?
> Yahoo! Mail Plus - Powerful. Affordable. Sign up
> now.
> http://mailplus.yahoo.com
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Do you Yahoo!?
Yahoo! Mail Plus - Powerful. Affordable. Sign up now.
