[Mapserver-users] Error Parsing POSTGIS connection informatio n
christian.schuster at rsag.ch
Thu Jan 30 00:37:30 EST 2003
This is a multipart message in MIME format.
--=_alternative 001EE6A8C1256CBE_=
Content-Type: text/plain; charset="US-ASCII"
ps -ef |grep postgres
gives the folowing result
$ ps -ef | grep postgres
user 1044 1556 con 09:23:25 /usr/bin/postgres
user 2028 1044 con 09:23:29 /usr/bin/postgres
user 1628 2028 con 09:23:29 /usr/bin/postgres
I am working on Win2000 station on which I have installed Cygwin. I do not
really have a Linux server. I hope this will not be the problem. I just do
not get where the problem really is. If it is PostgreSQL or PostGIS or
MapServer.
After I built MapServer I checked the capabilities of it which are
$ ./mapserv -v
MapServer version 3.6.3 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ
SUPPORTS=TTF SUPPORTS=WMS_SERVER INPUT=EPPL7 INPUT=JPEG
INPUT=POSTGIS INPUT=SHAPEFILE
I also tried some geometric functions like area in Postgre SQL which
worked fine. Therefore, I assume I have a problem in the Map file. I am
really not sure what is the min I have to define in the Map file.
The demo applikation is working fine and so I created my mapfile with
parts from there. My map file looks like this right now:
### Start of map file ###
MAP
NAME "MapServer"
STATUS ON
SIZE 600 600
EXTENT 0 0 100 100
UNITS METERS
#SHAPEPATH "data"
IMAGECOLOR 255 255 255
IMAGETYPE JPG
INTERLACE ON
SYMBOLSET "symbols/symbols.sym"
### Start of reference map ###
REFERENCE
### reference picture which must be a gif file acording to specs 3.6
### this is WRONG !!! GD 1.8 and higher do not support gif anymore
### For me it worked with a jpg or png picture
IMAGE "symbols/reference.png"
EXTENT 0 0 100 100
SIZE 50 50
STATUS ON
COLOR -1 -1 -1
OUTLINECOLOR 255 0 0
END ### end of reference
### Start of web interface definition (including WMS enabling metadata)
WEB
TEMPLATE demo.html
MINSCALE 0
MAXSCALE 1000
IMAGEPATH "set in demo_init.html" # no change required
IMAGEURL "set in demo_init.html" # no change required
METADATA
WMS_ACCESSCONSTRAINTS none
### change this value to match your setup
WMS_ONLINERESOURCE "http://localhost:8300/chstest/demo.html"
END
END ### end of web
### Start of layer definitions ###
LAYER
CONNECTIONTYPE postgis
NAME "points"
### Connect to a remote spatial database
CONNECTION "user=*** dbname=myGISdb host=localhost port=5432"
### Get the points from the 'col1' column of the 't1' table
DATA "col1 from t1"
STATUS ON
TYPE POINT
CLASS
COLOR 255 0 0
END
END
### end of layer definitions
END ### end of map File
Christian Schuster
Rudolf Schuster AG
Postfach 277
CH - 3000 Bern 11
http://www.rsag.ch
++41 31 348 05 30
Content-Type: text/html; charset="US-ASCII"
<br><font size=2>ps -ef |grep postgres</font>
<br>
<br><font size=2 face="sans-serif">gives the folowing result</font>
<br>
<br><font size=2 face="sans-serif"><b>$ ps -ef | grep postgres</b></font>
<br><font size=2 face="sans-serif"><b> user 1044
1556 con 09:23:25 /usr/bin/postgres</b></font>
<br><font size=2 face="sans-serif"><b> user 2028
1044 con 09:23:29 /usr/bin/postgres</b></font>
<br><font size=2 face="sans-serif"><b> user 1628
2028 con 09:23:29 /usr/bin/postgres</b></font>
<br>
<br><font size=2 face="sans-serif">I am working on Win2000 station on which
I have installed Cygwin. I do not really have a Linux server. I hope this
will not be the problem. I just do not get where the problem really is.
If it is PostgreSQL or PostGIS or MapServer.</font>
<br>
<br><font size=2 face="sans-serif">After I built MapServer I checked the
capabilities of it which are</font>
<br>
<br><font size=2 face="sans-serif"><b>$ ./mapserv -v</b></font>
<br><font size=2 face="sans-serif"><b>MapServer version 3.6.3 OUTPUT=PNG
OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ SUPPORTS=TTF SUPPORTS=WMS_SERVER
INPUT=EPPL7 INPUT=JPEG</b></font>
<br><font size=2 face="sans-serif"><b>INPUT=POSTGIS INPUT=SHAPEFILE</b></font>
<br>
<br><font size=2 face="sans-serif">I also tried some geometric functions
like area in Postgre SQL which worked fine. Therefore, I assume I have
a problem in the Map file. I am really not sure what is the min I have
to define in the Map file.</font>
<br><font size=2 face="sans-serif">The demo applikation is working fine
and so I created my mapfile with parts from there. My map file looks like
this right now:</font>
<br>
<br><font size=2 face="sans-serif"><b>#################################################################################</b></font>
<br><font size=2 face="sans-serif"><b>### Start of map file
###</b></font>
<br><font size=2 face="sans-serif"><b>MAP</b></font>
<br><font size=2 face="sans-serif"><b> NAME "MapServer"</b></font>
<br><font size=2 face="sans-serif"><b> </b></font>
<br><font size=2 face="sans-serif"><b> STATUS ON</b></font>
<br><font size=2 face="sans-serif"><b> SIZE 600 600</b></font>
<br><font size=2 face="sans-serif"><b> EXTENT 0 0 100 100</b></font>
<br><font size=2 face="sans-serif"><b> UNITS METERS</b></font>
<br><font size=2 face="sans-serif"><b> #SHAPEPATH "data"</b></font>
<br><font size=2 face="sans-serif"><b> IMAGECOLOR 255 255 255</b></font>
<br><font size=2 face="sans-serif"><b> IMAGETYPE JPG</b></font>
<br><font size=2 face="sans-serif"><b> INTERLACE ON</b></font>
<br><font size=2 face="sans-serif"><b> SYMBOLSET "symbols/symbols.sym"</b></font>
<br>
<br><font size=2 face="sans-serif"><b>##############################################################################</b></font>
<br><font size=2 face="sans-serif"><b>### Start of reference map
###</b></font>
<br><font size=2 face="sans-serif"><b>REFERENCE</b></font>
<br><font size=2 face="sans-serif"><b> ### reference picture which
must be a gif file acording to specs 3.6</b></font>
<br><font size=2 face="sans-serif"><b> ### this is WRONG !!! GD 1.8
and higher do not support gif anymore</b></font>
<br><font size=2 face="sans-serif"><b> ### For me it worked with
a jpg or png picture</b></font>
<br><font size=2 face="sans-serif"><b> IMAGE "symbols/reference.png"</b></font>
<br>
<br><font size=2 face="sans-serif"><b> SIZE 50 50</b></font>
<br><font size=2 face="sans-serif"><b> COLOR -1 -1 -1</b></font>
<br><font size=2 face="sans-serif"><b> OUTLINECOLOR 255 0 0</b></font>
<br><font size=2 face="sans-serif"><b>END ### end of reference</b></font>
<br>
<br><font size=2 face="sans-serif"><b>### Start of web interface definition
(including WMS enabling metadata) ###</b></font>
<br><font size=2 face="sans-serif"><b>WEB</b></font>
<br><font size=2 face="sans-serif"><b> TEMPLATE demo.html</b></font>
<br><font size=2 face="sans-serif"><b> MINSCALE 0</b></font>
<br><font size=2 face="sans-serif"><b> MAXSCALE 1000</b></font>
<br><font size=2 face="sans-serif"><b> IMAGEPATH "set
in demo_init.html" # no change required</b></font>
<br><font size=2 face="sans-serif"><b> IMAGEURL "set
<br><font size=2 face="sans-serif"><b> METADATA</b></font>
<br><font size=2 face="sans-serif"><b> WMS_ACCESSCONSTRAINTS
none</b></font>
<br>
<br><font size=2 face="sans-serif"><b> ### change this value
to match your setup</b></font>
<br><font size=2 face="sans-serif"><b> WMS_ONLINERESOURCE
"http://localhost:8300/chstest/demo.html"</b></font>
<br><font size=2 face="sans-serif"><b> END</b></font>
<br><font size=2 face="sans-serif"><b>END ### end of web</b></font>
<br><font size=2 face="sans-serif"><b>### Start of layer definitions
###</b></font>
<br><font size=2 face="sans-serif"><b>LAYER</b></font>
<br><font size=2 face="sans-serif"><b> CONNECTIONTYPE postgis</b></font>
<br><font size=2 face="sans-serif"><b> NAME "points"</b></font>
<br>
<br><font size=2 face="sans-serif"><b> ### Connect to a remote spatial
database</b></font>
<br><font size=2 face="sans-serif"><b> CONNECTION "user=***
dbname=myGISdb host=localhost port=5432"</b></font>
<br>
<br><font size=2 face="sans-serif"><b> ### Get the points from the
'col1' column of the 't1' table</b></font>
<br><font size=2 face="sans-serif"><b> DATA "col1 from t1"</b></font>
<br><font size=2 face="sans-serif"><b> TYPE POINT</b></font>
<br>
<br><font size=2 face="sans-serif"><b> CLASS</b></font>
<br><font size=2 face="sans-serif"><b> COLOR 255 0 0
</b></font>
<br><font size=2 face="sans-serif"><b>END</b></font>
<br><font size=2 face="sans-serif"><b>### end of layer definitions</b></font>
<br>
<br><font size=2 face="sans-serif"><b>END ### end of map File</b></font>
<br><font size=2 face="sans-serif"><br>
Christian Schuster<br>
<br>
Rudolf Schuster AG<br>
Postfach 277<br>
CH - 3000 Bern 11<br>
<br>
http://www.rsag.ch<br>
++41 31 348 05 30</font>
--=_alternative 001EE6A8C1256CBE_=--
