[Mapserver-users] Problem Selecting a Feature
Lowell Filak
lfilak at medinaco.org
Thu Jan 30 09:17:54 EST 2003
It's likely that adding a 'template' for the layer, even if it is bogus, may fix the problem.
HTH
Lowell F.
The following message was sent by "Benjamin Wragg" <bwragg at tpg.com.au> on Wed, 29 Jan 2003 10:00:09 +1030.
> Hi all,
> I have the following layer defined in my map file:
> LAYER
> CONNECTIONTYPE postgis
> NAME "testpoints"
> CONNECTION "user=user password=password dbname=dbname host=localhost"
> DATA "the_geom from testpoints"
> STATUS ON
> TYPE POINT
> CLASS
> NAME "All Points"
> COLOR 0 0 0
> SIZE 10
> SYMBOL 2
> END
> END
> If I run the following code:
> $layer=$map->getlayerbyname("aLayer");
> $class=ms_newClassObj($layer);
> $class->set("name", "Selected Feature");
> $class->setexpression('gid='.$featureGID);
> $colorId=$map->addColor(255,0,0);
> $class->set("color", $colorId);
> $class->set("size", 20);
> $class->set("symbol", 2);
> $layer->set("status", MS_ON);
> $image=$map->draw();
> $imageURL=$image->saveWebImage(MS_PNG,1,1,0);
> I also generate a legend and replace the images in the browser with the
> newly generated images. The problem is that I can't see the feature on
> the map, but a new class shows up on the legend. What am I missing?
> Thanks,
> Benjamin
