[Mapserver-users] query points
jose.quintal at cfe.gob.mx
Thu Jan 30 17:59:15 EST 2003
Hello. I am new with PHP/Mapscript and Mapserver.
I have points in a Table of Mysql with its coordinates.
This it is the code that I use to draw the points.
As I can do to him so that when selecting a point appears to me their data
$p=mysql_query($sql) or die("Error al Ejecutar la Consulta");
// get a layer object representing your pointlayer
$layerObj = $map->getLayerByName("points");
// get a class object representing the first class in the layer
$classObj = $layerObj->getClass(0);
// create a new point object to hold the X Y data
$pointObj = ms_newPointObj();
while($reg=mysql_fetch_array($p)){
$a=$reg['postes_id'];
$b=$reg['cor_x'];
$c=$reg['cor_y'];
//set the X Y values of the point object
$pointObj->setXY($b,$c);
$pointObj->draw($map, $layerObj, $image, 0, $a);
$image_url=$image->saveWebImage(MS_PNG,1,1,0);
I use Windows 2000, IIS, Mapserver 3.6.3 with PHP/Mapscript 4.2.2
Thanks for the aid.
José Antonio Quintal Castillo
