[Mapserver-users] RE: help with oid
Jan Hartmann
jhart at frw.uva.nl
Fri Jan 31 09:13:01 EST 2003
Ryanne,
It *has* to do with OID, and a clear explanation has been added recently
to the PostGIS documentation:
http://postgis.refractions.net/docs/x549.html#AEN607
Jan
ryanne cruz wrote:
> hi list.
> does anyone here know of a site that discusses oid? or can anyone here explain
> to me what oid is and how it is used?
> i am trying to set the data of a layer with a subselect as its argument.
> example is:
> $wind->set(data,"geom from (select geom AS geom from wind where
> provinceid=$provid and distance(wind.geom,(select geom from municipality where
> munprovid=$munprovid))<=0)");
> but it results to an error:
> Warning: MapServer Error in msPOSTGISLayerWhichShapes(): prep_DB:Error
> executing POSTGIS DECLARE statement (0.6 failed - retried 0.5 and it failed
> too). DECLARE mycursor BINARY CURSOR FOR SELECT
> watt_m2::text,asbinary(force_collection(force_2d(geom)),'NDR'),OID::text from
> (select geom AS geom from wind where provinceid=1 and
> distance(wind.geom,(select geom from municipality where munprovid=1))<=0)
> WHERE geom && setSRID('BOX3D(118.267071942857 9.300063,118.638417057143
> 9.670539)'::BOX3D, find_srid('','windcipality','geom') )
> and when i tried this:
> where provinceid=$provid and distance(wind.geom,(select geom from municipality
> where munprovid=$munprovid))<=0) as new_table using unique mun using
> SRID=-1");
> it reults to this error:
> MapServer Error in msPOSTGISLayerWhichShapes(): prep_DB:Error executing
> POSTGIS DECLARE statement (0.6 failed - retried 0.5 and it failed too).
> i was thinking that the solution may be with using an oid but i'm not sure
> what it is and how it works.
> help!?
> ryanne
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Jan Hartmann
Department of Geography
University of Amsterdam
jhart at frw.uva.nl
