[Mapserver-users] Querystring parameters for selecting OUTPUTFORMAT
Ed McNierney ed at topozone.com
Fri Jan 31 13:19:02 PST 2003
Daniel -
Thanks - Frank's already pointed me in the right direction, and I'll pass the code on to him for checkin when it's tested.
	- Ed
-----Original Message-----
From: Daniel Morissette [mailto:morissette at dmsolutions.ca]
Sent: Friday, January 31, 2003 4:17 PM
To: Ed McNierney
Cc: mapserver-users at lists.gis.umn.edu
Subject: Re: [Mapserver-users] Querystring parameters for selecting
OUTPUTFORMAT
Ed McNierney wrote:
> Specifically, I'm trying to define several named OUTPUTFORMATs in the MAP file and select one through a querystring parameter.  First, if there's already a way to do this, let me know because I couldn't find it.
I dunno.  I'll leave that one to Steve or Frank.
> I can define multiple OUTPUTFORMATs but I only get either the first one or the one specified in the IMAGETYPE statement.  I added code to mapserv.c in the "obvious place" where the CGI form variables are parsed; this looks for an IMAGETYPE variable and sets msObj->Map->imagetype to that string value.  However, it appears that in the earlier processing of the MAP file, the outputformats are enumerated and the default selected.  My setting of msObj->Map->imagetype has no effect because it seems the decisions' already been made.
You'll have to call msSelectOutputFormat() for the output format change
to take effect.
 Daniel Morissette               morissette at dmsolutions.ca
 DM Solutions Group              http://www.dmsolutions.ca/
More information about the MapServer-users mailing list
