[Mapserver-users] JpGraph + Mapserver 3.6.3 + php_mapscript
Daniel Morissette morissette at dmsolutions.ca
Fri Jan 31 14:51:29 PST 2003
Prashanth Ram wrote:
> Hi folks..
>   Has anyone tried to get JpGraph (1.x) and Mapserver + php_mapscript
> (3.6.3) working together on the same box. When I turn the php_mapscript
> extension on, JpGraph does not work, and when I turn it off
> php_mapscript does not work!
The problem is quite likely related to different versions of the GD
library being used by php_mapscript and by the php_gd module used by
JpGraph.  The solution is to make sure both modules are built using the
same GD and freetype if you can.
See bug 190 for more details:
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=190
 DM Solutions Group              http://www.dmsolutions.ca/
More information about the MapServer-users mailing list
