[Mapserver-users] can't get tutorial working on windows
Chris Black
cblack at CalAcademy.Org
Fri Jan 31 18:29:36 EST 2003
Folks,
I've downloaded the tutorial, and I'm trying to get section 3, example 2
working on windows and I just can't get it going. When I go to the url (
http://localhost/Scripts/mapserv.exe?map=c%3A%2Finetpub%2Fwwwroot%2Fmapserverapps%2Ftutorial35%2Fs3%2Fs3ex2.map&imgext=-97.500000+39.736083+-82.122902+51.269315&zoom=1
I get a page with the layout of the page I find at
http://terrasip.gis.umn.edu/cgi-bin/mapserv35?map=/data/projects/tutorial35/s3/s3ex2.map
. But where the map should be, it just says "Submit Query", and the
legend and reference image are blank. I modified the tutorial files to
have what I think are the correct paths and urls, but clearly I've done
something wrong. I'll include here my versions of s3ex2.map and
s3ex2.html as well as a directory listing of . I hope someone can find
where I've botched the paths, because it all looks ok to me.
Thank you for any help.
-- Chris
s3ex2.html
--------------- cut here -----------------------
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML//EN">
<html>
<head>
<title>MapServer 3.5 Tutorial</title>
<link type="text/css" rel="stylesheet"
href="/mapserverapps/tutorial35/ms35.css" />
</head>
<body>
<h3>Section 3<br>
Example 2 – Zoom Controls</h3>
<p>
<form method="GET" action="/Scripts/mapserv.exe">
<input type="hidden" name="map" value="[map]">
<input type="hidden" name="imgext" value="[mapext]">
[<a href="/mapserverapps/tutorial35/s3/s3ex2_map.html">map file
listing</a>]
[<a href="/mapserverapps/tutorial35/s3/s3ex2.html">template file
listing</a>]
<table border=1 cellpadding=3>
<tr>
<td align=center>
<input type="image" name="img" src="[img]" border="0">
</td>
<td valign=top>
<font size=+1 face=arial,helvetica>Map Controls</font>
<p>
Set your zoom option:<br>
<select name="zoom" size="1">
<option value="10" [zoom_10_select]> Zoom in 10 times
<option value="8" [zoom_8_select]> Zoom in 8 times
<option value="4" [zoom_4_select]> Zoom in 4 times
<option value="3" [zoom_3_select]> Zoom in 3 times
<option value="2" [zoom_2_select]> Zoom in 2 times
<option value="1" [zoom_1_select]> Recenter Map
<option value="-2" [zoom_-2_select]> Zoom out 2 times
<option value="-3" [zoom_-3_select]> Zoom out 3 times
<option value="-4" [zoom_-4_select]> Zoom out 4 times
<option value="-8" [zoom_-8_select]> Zoom out 8 times
<option value="-10" [zoom_-10_select]> Zoom out 10 times
</select>
<p>
<font face=arial,helvetica><b>Legend</b></font><br>
<img src="[legend]"><p>
<img src="[ref]">
</td>
</tr></table>
<p> <a href="index.html">Back to Section 3</a> | <a
href="/Scripts/mapserv.exe?map=c:\inetpub\wwwroot\mapserverapps\tutorial35\s3\s3ex3.map&layer=water&layer=states&zoom=1&submit=Redraw">Proceed
to Example 3</a>
</form>
</body>
</html>
-------------- cut here -------------------------
s3ex2.map
---------------- cut here --------------------------
NAME S3EX1
EXTENT -97.5 41.619778 -82.122902 49.38562
SIZE 400 300
SHAPEPATH "c:/inetpub/wwwroot/mapserverapps/tutorial35/data"
FONTSET "c:/inetpub/wwwroot/mapserverapps/fonts/fonts.list"
SYMBOLSET
"c:/inetpub/wwwroot/mapserverapps/tutorial35/symbols/symbols35.sym"
WEB
TEMPLATE s3ex2.html
IMAGEPATH "c:/inetpub/wwwroot/mapserverapps/data/tmp/"
IMAGEURL "http://localhost/mapserverapps/data/tmp/"
END
LEGEND
STATUS ON
LABEL
TYPE TRUETYPE
FONT arial
COLOR 0 0 0
SIZE 12
ANTIALIAS TRUE
END
END
REFERENCE
STATUS ON
IMAGE "../images/ref1.gif"
SIZE 150 113
COLOR -1 -1 -1
OUTLINECOLOR 255 0 0
END
# LAYER DEFINITIONS ---------------------------------------------
LAYER # Shaded Relief Raster
NAME "relief"
DATA "raster/shdrlfi020g_ugl.tif"
STATUS DEFAULT
TYPE RASTER
OFFSITE 0
END
LAYER # States
NAME "states"
DATA states_ugl
STATUS OFF
TYPE POLYGON
# CLASSITEM "CLASS"
CLASS # States class
NAME "States"
EXPRESSION ('[CLASS]' eq 'land')
# EXPRESSION 'land'
COLOR 240 240 240
OUTLINECOLOR 0 0 0
END # end of States class object
END # end of layer object
LAYER # water features layer
NAME "water features"
DATA hydrop_ugl
STATUS DEFAULT
TYPE POLYGON
CLASSITEM "FEATURE"
CLASS
NAME "Bay/Estuarine"
EXPRESSION /Bay*/
COLOR 164 164 255
END
CLASS
NAME "Lakes/Reservoir"
EXPRESSION ('[FEATURE]' eq 'Lake' or '[FEATURE]' = 'Reservoir')
COLOR 64 64 255
END
CLASS
NAME "Marsh/Swamp"
EXPRESSION /Sw*/
COLOR 210 235 255
END
CLASS
NAME "Major Rivers"
EXPRESSION 'Stream'
COLOR 128 128 220
END
CLASS
NAME "Canal"
EXPRESSION 'Canal'
COLOR 200 128 255
END
END # end of water features layer
#LAYER # Roads
# NAME "roads"
# DATA roads_ugl
# TYPE LINE
# STATUS DEFAULT
# CLASSITEM "CLASS"
# CLASS
# NAME "Interstate Highways"
# EXPRESSION 'Interstate'
# COLOR 128 0 0
# SYMBOL 'circle'
# SIZE 2
# END
# CLASS
# NAME "US Highways"
# EXPRESSION 'US'
# COLOR 255 128 0
# SYMBOL 'line1'
# SIZE 1
# END
#END
LAYER # States
NAME "states"
DATA states_ugl
STATUS DEFAULT
TYPE LINE
# CLASSITEM "CLASS"
NAME "States"
# EXPRESSION 'land'
COLOR 0 0 0
LAYER # States
NAME "states"
DATA states_ugl
STATUS DEFAULT
TYPE ANNOTATION
LABELITEM "STATE"
CLASSITEM "CLASS"
EXPRESSION 'land'
COLOR -1 -1 -1
LABEL
COLOR 132 31 31
SHADOWCOLOR 218 218 218
SHADOWSIZE 2 2
TYPE TRUETYPE
FONT arial-bold
SIZE 14
ANTIALIAS TRUE
POSITION CL
PARTIALS FALSE
MINDISTANCE 250
BUFFER 4
END # end of label
END # end of map file
---------------- cut here ---------------------------
Directory listing -- this looks like a Unix directory listing because
it's the output of the cygwin command "ls - R" in the directory
c:\inetpub\wwwroot
This is a Windows system, though.
total 47
drwxr-xr-x 6 Administ None 4096 Jan 31 15:25 MapServerApps
drwxrwxrwx 2 Administ None 0 Jan 7 13:32 _private
drwxr-xr-x 2 Administ None 4096 Jan 10 10:16 _vti_cnf
-rwxr-xr-x 1 Administ None 1759 Jan 7 13:32 _vti_inf.html
drwxrwxrwt 2 Administ None 0 Jan 7 13:32 _vti_log
drwxrwxrwt 2 Administ None 4096 Jan 10 10:20 _vti_pvt
drwxr-xr-x 2 Administ None 0 Jan 7 13:32 _vti_script
drwxrwxrwt 2 Administ None 0 Jan 7 13:32 _vti_txt
-rwxr-xr-x 1 Administ None 451 Jan 7 13:49 default.htm
-rw-rw-rw- 1 Administ None 0 Jan 31 15:28 flist.out
-rwxr-xr-x 1 Administ None 79 Feb 17 1998 global.asa
-rwxr-xr-x 1 Administ None 1736 Jun 4 1999 iisstart.asp
drwxr-xr-x 2 Administ None 0 Jan 7 13:32 images
-rwxr-xr-x 1 Administ None 7240 Sep 22 1999 localstart.asp
-rwxr-xr-x 1 Administ None 1684 Jan 24 11:08
mapserver_documentation.htm
-rwxr-xr-x 1 Administ None 2497 Jan 7 13:32 postinfo.html
drwxrwxrwx 2 Administ None 0 Jan 31 15:27 tmp
./MapServerApps:
total 8
drwxr-xr-x 5 Administ None 0 Jan 31 14:55 data
drwxr-xr-x 2 Administ None 4096 Jan 31 14:34 fonts
drwxr-xr-x 2 Administ None 0 Jan 27 16:22 images
drwxr-xr-x 12 Administ None 4096 Jan 31 14:21 tutorial35
./MapServerApps/data:
total 0
drwxr-xr-x 2 Administ None 0 Jan 27 16:22 raster
drwxr-xr-x 2 Administ None 0 Jan 31 14:55 tmp
drwxr-xr-x 2 Administ None 0 Jan 27 16:22 vector
./MapServerApps/data/raster:
total 0
./MapServerApps/data/tmp:
total 0
./MapServerApps/data/vector:
total 0
./MapServerApps/fonts:
total 547
-rwxr-xr-x 1 Administ None 273020 Jul 26 2000 ARIAL.TTF
-rwxr-xr-x 1 Administ None 284560 Jul 26 2000 ARIALBD.TTF
-rwxr-xr-x 1 Administ None 41 Jan 31 14:21 fonts.list
-rwxr-xr-x 1 Administ None 71 Jan 31 14:15 fonts.list~
./MapServerApps/images:
total 0
./MapServerApps/tutorial35:
total 69
-rwxr-xr-x 1 Administ None 1130 Jul 6 2002 LICENSE.txt
drwxr-xr-x 3 Administ None 16384 Jan 31 13:32 data
-rwxr-xr-x 1 Administ None 1069 Apr 26 2002 download.html
-rwxr-xr-x 1 Administ None 75 Jan 31 14:14 fonts.list~
drwxr-xr-x 2 Administ None 0 Jan 31 13:32 images
-rwxr-xr-x 1 Administ None 8713 Jul 6 2002 index.html
drwxr-xr-x 2 Administ None 4096 Jan 31 13:32 java
-rwxr-xr-x 1 Administ None 2574 Mar 8 2002 markup.css
-rwxr-xr-x 1 Administ None 860 Apr 14 2002 ms35.css
drwxr-xr-x 2 Administ None 4096 Jan 31 13:32 s1
drwxr-xr-x 2 Administ None 4096 Jan 31 13:32 s2
drwxr-xr-x 2 Administ None 8192 Jan 31 15:01 s3
drwxr-xr-x 2 Administ None 4096 Jan 31 13:32 s4
drwxr-xr-x 2 Administ None 4096 Jan 31 13:32 s5
drwxr-xr-x 2 Administ None 4096 Jan 31 13:32 s6
-rwxr-xr-x 1 Administ None 1628 Jul 6 2002 sections.html
drwxr-xr-x 2 Administ None 0 Jan 31 13:32 symbols
-rwxr-xr-x 1 Administ None 118 Apr 11 2002 tutorial35_tree.txt
./MapServerApps/tutorial35/data:
total 16978
-rwxr-xr-x 1 Administ None 43103 Mar 7 2002 co2000_ugl.dbf
-rwxr-xr-x 1 Administ None 10180 Mar 7 2002 co2000_ugl.sbn
-rwxr-xr-x 1 Administ None 900 Mar 7 2002 co2000_ugl.sbx
-rwxr-xr-x 1 Administ None 667172 Mar 7 2002 co2000_ugl.shp
-rwxr-xr-x 1 Administ None 3708 Mar 7 2002 co2000_ugl.shx
-rwxr-xr-x 1 Administ None 25673 Feb 6 2002 co2000p020.txt
-rwxr-xr-x 1 Administ None 210750 Mar 7 2002 fedlan_ugl.dbf
-rwxr-xr-x 1 Administ None 227456 Mar 7 2002 fedlan_ugl.shp
-rwxr-xr-x 1 Administ None 2500 Mar 7 2002 fedlan_ugl.shx
-rwxr-xr-x 1 Administ None 41117 Jan 15 2002 fedlanp020.txt
-rwxr-xr-x 1 Administ None 33429 Sep 27 2001 hydrogm020.txt
-rwxr-xr-x 1 Administ None 1183928 Mar 7 2002 hydrol_ugl.dbf
-rwxr-xr-x 1 Administ None 2332764 Mar 7 2002 hydrol_ugl.shp
-rwxr-xr-x 1 Administ None 39884 Mar 7 2002 hydrol_ugl.shx
-rwxr-xr-x 1 Administ None 506006 Mar 7 2002 hydrop_ugl.dbf
-rwxr-xr-x 1 Administ None 2290160 Mar 7 2002 hydrop_ugl.shp
-rwxr-xr-x 1 Administ None 17244 Mar 7 2002 hydrop_ugl.shx
-rwxr-xr-x 1 Administ None 3619390 Mar 7 2002 plss00_ugl.dbf
-rwxr-xr-x 1 Administ None 1370568 Mar 7 2002 plss00_ugl.shp
-rwxr-xr-x 1 Administ None 52172 Mar 7 2002 plss00_ugl.shx
-rwxr-xr-x 1 Administ None 30501 Aug 27 2001 plss00p020.txt
drwxr-xr-x 2 Administ None 4096 Jan 31 13:32 raster
-rwxr-xr-x 1 Administ None 1049116 Mar 14 2002 roads.dbf
-rwxr-xr-x 1 Administ None 40964 Mar 14 2002 roads.sbn
-rwxr-xr-x 1 Administ None 3908 Mar 14 2002 roads.sbx
-rwxr-xr-x 1 Administ None 766496 Mar 14 2002 roads.shp
-rwxr-xr-x 1 Administ None 29332 Mar 14 2002 roads.shx
-rwxr-xr-x 1 Administ None 1049116 Apr 23 2002 roads_ugl.dbf
-rwxr-xr-x 1 Administ None 766496 Mar 7 2002 roads_ugl.shp
-rwxr-xr-x 1 Administ None 29332 Mar 7 2002 roads_ugl.shx
-rwxr-xr-x 1 Administ None 31134 Sep 25 2001 roadtrl020.txt
-rwxr-xr-x 1 Administ None 13078 Mar 7 2002 states_ugl.dbf
-rwxr-xr-x 1 Administ None 520236 Mar 7 2002 states_ugl.shp
-rwxr-xr-x 1 Administ None 1732 Mar 7 2002 states_ugl.shx
-rwxr-xr-x 1 Administ None 19317 Sep 6 2001 statesp020.txt
-rwxr-xr-x 1 Administ None 111 Mar 7 2002 uglbound.dbf
-rwxr-xr-x 1 Administ None 81868 Mar 7 2002 uglbound.shp
-rwxr-xr-x 1 Administ None 108 Mar 7 2002 uglbound.shx
-rwxr-xr-x 1 Administ None 58761 Mar 7 2002 urban_ugl.dbf
-rwxr-xr-x 1 Administ None 168412 Mar 7 2002 urban_ugl.shp
-rwxr-xr-x 1 Administ None 4172 Mar 7 2002 urban_ugl.shx
-rwxr-xr-x 1 Administ None 17679 Oct 29 2001 urbanap020.txt
./MapServerApps/tutorial35/data/raster:
total 15829
-rwxr-xr-x 1 Administ None 6529545 Apr 24 2002
mod13a12000257evi.tif
-rwxr-xr-x 1 Administ None 6433369 Apr 23 2002
mod13a12000257evi_l.tif
-rwxr-xr-x 1 Administ None 2118176 Apr 24 2002 shdrlfi020g_ugl.tif
-rwxr-xr-x 1 Administ None 94 Mar 13 2002 shdrlfi020g_ugl.wld
-rwxr-xr-x 1 Administ None 1123518 Apr 14 2002 shdrlfi020l_ugl.tif
-rwxr-xr-x 1 Administ None 87 Apr 14 2002 shdrlfi020l_ugl.wld
./MapServerApps/tutorial35/images:
total 6
./MapServerApps/tutorial35/java:
total 29
-rwxr-xr-x 1 Administ None 2691 Dec 22 2000 README
-rwxr-xr-x 1 Administ None 1243 Feb 13 2001 evalThread.class
-rwxr-xr-x 1 Administ None 6600 Feb 13 2001 mapplet.class
-rwxr-xr-x 1 Administ None 7918 Feb 2 2001 mapplet.java
-rwxr-xr-x 1 Administ None 8471 Jul 6 2001 mapplet.zip
./MapServerApps/tutorial35/s1:
total 23
-rwxr-xr-x 1 Administ None 1098 Apr 26 2002 index.html
-rwxr-xr-x 1 Administ None 1891 Apr 30 2002 s1ex1.html
-rwxr-xr-x 1 Administ None 709 Apr 30 2002 s1ex1.map
-rwxr-xr-x 1 Administ None 1814 Mar 14 2002 s1ex1_code.html
-rwxr-xr-x 1 Administ None 1211 Apr 30 2002 s1ex1_map.html
-rwxr-xr-x 1 Administ None 1239 Apr 28 2002 s1ex2.html
-rwxr-xr-x 1 Administ None 1644 Apr 30 2002 s1ex2.map
-rwxr-xr-x 1 Administ None 1774 Mar 14 2002 s1ex2_code.html
-rwxr-xr-x 1 Administ None 1445 Mar 14 2002 s1ex2_map.html
-rwxr-xr-x 1 Administ None 970 Apr 28 2002 s1ex3.html
-rwxr-xr-x 1 Administ None 738 Apr 30 2002 s1ex3.map
-rwxr-xr-x 1 Administ None 1906 Mar 14 2002 s1ex3_code.html
-rwxr-xr-x 1 Administ None 1170 Mar 14 2002 s1ex3_map.html
./MapServerApps/tutorial35/s2:
total 37
-rwxr-xr-x 1 Administ None 1377 May 2 2002 index.html
-rwxr-xr-x 1 Administ None 1221 Apr 28 2002 s2ex1.html
-rwxr-xr-x 1 Administ None 712 Mar 14 2002 s2ex1.map
-rwxr-xr-x 1 Administ None 933 Mar 14 2002 s2ex1_code.html
-rwxr-xr-x 1 Administ None 1420 Mar 14 2002 s2ex1_map.html
-rwxr-xr-x 1 Administ None 974 Apr 28 2002 s2ex2.html
-rwxr-xr-x 1 Administ None 1117 Mar 14 2002 s2ex2.map
-rwxr-xr-x 1 Administ None 1119 Mar 14 2002 s2ex2_code.html
-rwxr-xr-x 1 Administ None 1597 Apr 28 2002 s2ex2_map.html
-rwxr-xr-x 1 Administ None 2199 Apr 28 2002 s2ex3.html
-rwxr-xr-x 1 Administ None 1542 Apr 26 2002 s2ex3.map
-rwxr-xr-x 1 Administ None 2022 Apr 28 2002 s2ex3_map.html
-rwxr-xr-x 1 Administ None 1057 Apr 28 2002 s2ex4.html
-rwxr-xr-x 1 Administ None 2009 Apr 26 2002 s2ex4.map
-rwxr-xr-x 1 Administ None 2489 Apr 28 2002 s2ex4_map.html
-rwxr-xr-x 1 Administ None 1781 Apr 28 2002 s2ex5.html
-rwxr-xr-x 1 Administ None 2122 Apr 26 2002 s2ex5.map
-rwxr-xr-x 1 Administ None 2602 May 2 2002 s2ex5_map.html
./MapServerApps/tutorial35/s3:
total 61
-rwxr-xr-x 1 Administ None 12 Nov 22 2000 county_footer.html
-rwxr-xr-x 1 Administ None 135 May 2 2002 county_header.html
-rwxr-xr-x 1 Administ None 43 May 6 2002 county_query.html
-rwxr-xr-x 1 Administ None 12 Nov 22 2000 fed_footer.html
-rwxr-xr-x 1 Administ None 193 May 2 2002 fed_header.html
-rwxr-xr-x 1 Administ None 114 May 2 2002 fed_query.html
-rwxr-xr-x 1 Administ None 451 Jul 5 2002 footer.html
-rwxr-xr-x 1 Administ None 154 May 2 2002 header.html
-rwxr-xr-x 1 Administ None 1590 Jan 31 13:44 index.html
-rwxr-xr-x 1 Administ None 1536 Jan 31 13:42 index.html~
-rwxr-xr-x 1 Administ None 4690 May 2 2002 s3ex1.html
-rwxr-xr-x 1 Administ None 1958 Jan 31 14:34 s3ex2.html
-rwxr-xr-x 1 Administ None 1943 Jan 31 14:31 s3ex2.html~
-rwxr-xr-x 1 Administ None 3120 Jan 31 15:01 s3ex2.map
-rwxr-xr-x 1 Administ None 3115 Jan 31 15:00 s3ex2.map~
-rwxr-xr-x 1 Administ None 3482 May 2 2002 s3ex2_map.html
-rwxr-xr-x 1 Administ None 2803 Jul 5 2002 s3ex3.html
-rwxr-xr-x 1 Administ None 2918 Apr 26 2002 s3ex3.map
-rwxr-xr-x 1 Administ None 3398 May 2 2002 s3ex3_map.html
-rwxr-xr-x 1 Administ None 3185 Jul 5 2002 s3ex4.html
-rwxr-xr-x 1 Administ None 3571 Jul 5 2002 s3ex4.map
-rwxr-xr-x 1 Administ None 3398 May 2 2002 s3ex4_map.html
-rwxr-xr-x 1 Administ None 12 Nov 22 2000 urban_footer.html
-rwxr-xr-x 1 Administ None 136 May 2 2002 urban_header.html
-rwxr-xr-x 1 Administ None 41 May 2 2002 urban_query.html
-rwxr-xr-x 1 Administ None 12 Nov 22 2000 water_footer.html
-rwxr-xr-x 1 Administ None 162 May 2 2002 water_header.html
-rwxr-xr-x 1 Administ None 59 May 2 2002 water_query.html
./MapServerApps/tutorial35/s4:
total 27
-rwxr-xr-x 1 Administ None 2670 Jul 5 2002 index.html
-rwxr-xr-x 1 Administ None 2508 Jul 5 2002 s4ex1.html
-rwxr-xr-x 1 Administ None 3754 Jul 5 2002 s4ex1.map
-rwxr-xr-x 1 Administ None 4533 Jul 5 2002 s4ex1_map.html
-rwxr-xr-x 1 Administ None 2499 Jul 5 2002 s4ex2.html
-rwxr-xr-x 1 Administ None 3835 Jul 5 2002 s4ex2.map
-rwxr-xr-x 1 Administ None 4509 Jul 5 2002 s4ex2_map.html
./MapServerApps/tutorial35/s5:
total 27
-rwxr-xr-x 1 Administ None 2215 Jul 5 2002 index.html
-rwxr-xr-x 1 Administ None 2941 Apr 24 2002 s5ex1.html
-rwxr-xr-x 1 Administ None 4056 Jul 5 2002 s5ex1.map
-rwxr-xr-x 1 Administ None 4535 Jul 5 2002 s5ex1_map.html
-rwxr-xr-x 1 Administ None 3052 Jul 5 2002 s5ex3.html
-rwxr-xr-x 1 Administ None 9009 Jul 6 2002 s5ex3.map
./MapServerApps/tutorial35/s6:
total 32
-rwxr-xr-x 1 Administ None 451 Jul 6 2002 footer.html
-rwxr-xr-x 1 Administ None 2261 Jul 6 2002 index.html
-rwxr-xr-x 1 Administ None 4039 Jul 6 2002 s6ex1.html
-rwxr-xr-x 1 Administ None 10467 Jul 6 2002 s6ex1.map
./MapServerApps/tutorial35/symbols:
total 2
-rwxr-xr-x 1 Administ None 1166 Jan 9 2002 symbols35.sym
./_private:
total 0
./_vti_cnf:
total 15
-rwxr-xr-x 1 Administ None 791 Jan 7 13:49 default.htm
-rwxr-xr-x 1 Administ None 380 Jan 7 13:32 global.asa
-rwxr-xr-x 1 Administ None 344 Jan 7 13:32 help.gif
-rwxr-xr-x 1 Administ None 562 Jan 7 13:32 iisstart.asp
-rwxr-xr-x 1 Administ None 1075 Jan 7 13:32 localstart.asp
-rwxr-xr-x 1 Administ None 2080 Jan 10 11:07
-rwxr-xr-x 1 Administ None 344 Jan 7 13:32 mmc.gif
-rwxr-xr-x 1 Administ None 341 Jan 7 13:32 pagerror.gif
-rwxr-xr-x 1 Administ None 345 Jan 7 13:32 print.gif
-rwxr-xr-x 1 Administ None 345 Jan 7 13:32 warning.gif
-rwxr-xr-x 1 Administ None 345 Jan 7 13:32 web.gif
-rwxr-xr-x 1 Administ None 347 Jan 7 13:32 win2000.gif
./_vti_log:
total 0
./_vti_pvt:
total 18
-rwxrwxrwx 1 Administ None 113 Jan 7 13:32 access.cnf
-rwxrwxrwx 1 Administ None 146 Jan 7 13:32 botinfs.cnf
-rwxrwxrwx 1 Administ None 323 Jan 7 13:32 bots.cnf
-rwxrwxrwx 1 Administ None 324 Jan 10 11:07 deptodoc.btr
-rwxrwxrwx 1 Administ None 5616 Jan 10 11:07 doctodep.btr
-rwxrw-rw- 1 Administ None 0 Jan 7 13:32 frontpg.lck
-rwxrwxrwx 1 Administ None 1125 Jan 10 10:20 linkinfo.cnf
-rwxrw-rw- 1 Administ None 1437 Jan 7 13:43 service.cnf
-rwxrw-rw- 1 Administ None 0 Jan 10 11:07 service.lck
-rwxrwxrwx 1 Administ None 3 Jan 7 13:32 services.cnf
-rwxrwxrwx 1 Administ None 89 Jan 10 10:20 structure.cnf
-rwxrwxrwx 1 Administ None 66 Jan 7 13:32 svcacl.cnf
-rwxrw-rw- 1 Administ None 0 Jan 7 13:32 uniqperm.cnf
-rwxrwxrwx 1 Administ None 25 Jan 7 13:32 writeto.cnf
./_vti_script:
total 0
./_vti_txt:
total 0
./images:
total 0
./tmp:
total 0
----------------------- cut here -----------------------
