[Mapserver-users] Maplab error
Vincent Schut
schut at sarvision.com
Tue Jul 1 09:38:27 EDT 2003
If I remember well these kind of errors usually means that there is an error
in your mapfile.
getSymbol is a function that is called by the mapfile parser to read
something. In this case it has something to do with the word 'LOCAL' on (or
around) line 17 of the map file (sam.map in this case).
sorry don't know much about maplab, that probably generated that mapfile?
But in mapserver terminology, this is more or less what the error means.
Regards,
Vincent Schut.
On Tuesday 01 July 2003 13:48, Rajkumar Singh wrote:
> Hi,
> Could anyone tell me what the following error mean? I received this while
> trying to use the MapBrowser component of Maplab.
> " PHP Warning: MapServer Error in getSymbol(): (LOCAL):(17) in
> c:\inetpub\wwwroot\maplab\htdocs\common\wrapper\map session.php on line 208
> PHP Fatal error: Failed to open map file
> c:/Inetpub///wwwroot/maplab///sam.map in
> 208"
> Any ideas what I'm doing wrong. I'm running Windows XP pro with IIS, PHP
> 4.3 and PHP Mapscript 3.6.4.
> Thanks for all replies.
> Cheers.
> Raj
______________________________________
Vincent Schut
Sarvision B.V.
Wageningen, The Netherlands
www.sarvision.com
