[Mapserver-users] getShare raises assertion error on PostGIS
Rainer Spittel
rasp at tzi.de
Tue Jul 1 10:53:18 EDT 2003
I am using Apache, the MapServer V3.6 and PostGIS as the
geodatabase. Both is running on Linux Suse 8.0. I have imported my
shapefiles into the PostGIS database and now I get the following error
message when I try to query an item:
Dump query
Query layer 0: built-up-area
Query layer built-up-area: skip this layer
Query layer 1: vegetation-zone
field opened
Inserting results 0
ShapeIndex:99923
TileIndex: -1
ClassIndex:0
Fatal error: Assertion failed, Could not set shape values: 0, 0 in
/usr/local/apache/htdocs/mapserver/test_map/htdocs/mapserv.php3 on line 737
The php-document look like this:
printf("Inserting results %s<BR>\n",$iRes);
$oRes = $oLayer->getResult($iRes);
printf("ShapeIndex:%s<BR>",$oRes->shapeindex);
printf("TileIndex: %s<BR>",$oRes->tileindex);
printf("ClassIndex:%s<BR>",$oRes->classindex);
$oShape = $oLayer->getShape($oRes->tileindex,$oRes->shapeindex);
printf("<TR>\n");
This error occures when the "getShape" methode will be processed. When I
look into the postgis database, I am not able to find an object with
this id. A dump of the table "vegetation-zone" looks like:
gid kn gn area the_geom
0 04000000 Bremen 578682.171
SRID=-1;MULTIPOLYGON(((3476450.95, [...])
1 04000000 Bremen 77603646.804
SRID=-1;MULTIPOLYGON(((3475408.58, [...])
Is the internal SRID wrong or what am I doing wrong?
R. Spittel
