[Mapserver-users] getShare raises assertion error on PostGIS
Nicol Hermann
mapserver at geochem.de
Tue Jul 1 14:59:59 EDT 2003
Hi Daniel,
thank you for the fix in the CVS version.
The error message disappears when i use the latest cvs version but i
still got no data back.The result of the var_dump statement is NULL.
How do i manage it to get the "real" data back from the postgres
database.
$shape = $layer->getShape($result->tileindex, $result->shapeindex);
$value = $shape ->value;
var_dump ($value);
Thanks a lot
Nicol
Am Die, 2003-07-01 um 17.33 schrieb Daniel Morissette:
> Rainer Spittel wrote:
> > Fatal error: Assertion failed, Could not set shape values: 0, 0 in
> > /usr/local/apache/htdocs/mapserver/test_map/htdocs/mapserv.php3 on line 737
> This is fixed in version 4.0 (CVS). We are unlikely to release another
> 3.6.x release since we plan on releasing 4.0 in a few weeks, so you
> might have to consider upgrading.
Nicol Hermann <mapserver at geochem.de>
