[mapserver-users] Oracle Spatial error info gone in 4.0?
Bart van den Eijnden
bartvde at xs4all.nl
Tue Jul 1 15:36:20 EDT 2003
what has happened to the Oracle Spatial error messages in 4.0 beta?
In old versions when you supplied an invalid column in the DATA statement,
you got an exception in your browser containing the Oracle SQL statement in
the ORA error, which is quite useful. Now I only get the error message:
msDrawMap(): Image handling error. Failed to draw layer named 'kwadranten'
In the "old" documentation there is also something about this (see
http://mapserver.gis.umn.edu/doc36/mapfile-reference.html):
For Oracle, use "shape FROM table" or "shape FROM (SELECT statement)" or
even more complex Oracle compliant queries! Note that there are important
performance impacts when using spatial subqueries however. Try using
MapServer's FILTER whenever possible instead. You can also see the SQL
submitted by forcing an error, for instance by submitting a DATA parameter
you know won't work, using for example a bad column name.
Best regards,
Bart
