[Mapserver-users] perl mapscript error
Aaron D. Hunt
hunt at zedxinc.com
Tue Jul 1 17:11:56 EDT 2003
Is there something I am missind in this confg. to use local lib installs?
./configure --without-tiff --with-proj=/usr/home/mapserver/proj-4.4.7/ --wit
h-gdal=/usr/home/mapserver/gdal-cvs-030626/bin/gdal-config --with-ogr=/usr/h
ome/mapserver/gdal-cvs-030626 --with-jpeg --with-wmsclient --with-freetype=/
usr/home/mapserver/freetype-2.1.4 --with-gd=/usr/home/mapserver/gd-2.0.15
I am directing mapserver to use local install versions of libs, but it seems
to be picking its own to use. Is there a option to force the use of local
libs
When I do the ldd mapserv I get
libgd.so.2 => not found
libjpeg.so.62 => /usr/lib/libjpeg.so.62 (0x40029000)
libfreetype.so.6 => /usr/lib/libfreetype.so.6 (0x40048000)
libpng.so.2 => /usr/lib/libpng.so.2 (0x40087000)
libz.so.1 => /usr/lib/libz.so.1 (0x400aa000)
libproj.so.0 => /usr/local/lib/libproj.so.0 (0x400b8000)
libgdal.1.1.so => /usr/local/lib/libgdal.1.1.so (0x400e9000)
libcurl.so.2 => /usr/local/lib/libcurl.so.2 (0x40276000)
libssl.so.1 => /usr/lib/libssl.so.1 (0x4029b000)
libcrypto.so.1 => /usr/lib/libcrypto.so.1 (0x402c8000)
libdl.so.2 => /lib/libdl.so.2 (0x40385000)
libm.so.6 => /lib/libm.so.6 (0x4038a000)
libc.so.6 => /lib/libc.so.6 (0x403ac000)
libungif.so.4 => /usr/lib/libungif.so.4 (0x404e2000)
libtiff.so.3 => /usr/lib/libtiff.so.3 (0x404ea000)
libstdc++-libc6.2-2.so.3 => /usr/lib/libstdc++-libc6.2-2.so.3
(0x4052d000)
/lib/ld-linux.so.2 => /lib/ld-linux.so.2 (0x40000000)
libX11.so.6 => /usr/X11R6/lib/libX11.so.6 (0x40570000)
----- Original Message -----
To: "Aaron D. Hunt" <hunt at zedxinc.com>; "Lowell Filak" <lfilak at medinaco.org>
Sent: Tuesday, July 01, 2003 4:08 PM
Subject: Re: [Mapserver-users] perl mapscript error
> Check out
> http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?PerlMapScriptDebugging
> and in particular the sections provided by Frank W. & Daniel M.
> I think the important option to start with here is "ldd mapserv" to see
> what the compilation is trying to use.
> Lowell
> The following message was sent by "Aaron D. Hunt" <hunt at zedxinc.com> on
> Tue, 1 Jul 2003 15:13:56 -0400.
> > I am using a local install of all the libraries. Is there a way to tell
> > which one it is trying to use.
> > From: "Lowell Filak" <lfilak at medinaco.org>
> > To: <mapserver-users at lists.gis.umn.edu>; <hunt at zedxinc.com>
> > Sent: Tuesday, July 01, 2003 3:09 PM
> > > Possibly an issue of library confusion?
> > > Lowell
http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0206/msg00385.html
