[Mapserver-users] mapscript 3.7 $layer->draw() problems
Bart van Heijningen bart at atsence.nl
Wed Jul 2 08:39:44 PDT 2003
This is a multi-part message in MIME format.
------=_NextPart_000_0030_01C340C0.EFFB53F0
Content-Type: text/plain;
	charset="US-ASCII"
Content-Transfer-Encoding: 7bit
Hi all,
I use Mapserver 4 with php mapscript
Here's the thing,
I am trying to draw newRectObj() on a map.
The size and position are generated from mysql
However I think I am missing something.
What am I doing wrong here. I have been struggling with this for a few days
now, help would be higly appreciated.
Thanks,
Bart
// the map
$wvimap = ms_newMapObj("rdm3.map");
$wvimap->selectOutputFormat('png24');
$wviimg = $wvimap->draw();
$imageobject = $wviimg->saveImage(test);
//  get correct layer
$wvilayer = $wvimap->getLayerByName("$bleble");
//$layerhandle = $wvilayer->open('$shpFname',1);
// Zoek in deze layer de eerste class
$classObj = $wvilayer->getClass(0);
echo "classobject = $classObj<br>\n";
$wvilayer->set("name", "$bleble");
$wvilayer->set (status,MS_ON);
$wvilayer->set (type,MS_POLYGON);
$wvilayer->set (classitem,$classObj);
$wvilayer->set (labelitem,"WVI");
$wvilayer->set (data,"$shpFname");
$wvilayer->draw($wvimap,$classObj);
// Declaration of the rectangle object
$rectangle = ms_newRectObj();
// Here I calculate the values of the rectangle
$rectangle->set("minx",($hshift+($measurements)*($rd_x)));
$rectangle->set("miny",(($vshift+($measurements)*($rd_y))));
$rectangle->set("maxx",(($hshift+(($measurements)*($rd_x)+($barwidth)))));
$rectangle->set("maxy",(($measurements)*($rd_y) +
(($maxbarheight/$maxvalue)*($measurements))+($barminheight)));
echo "minx = $rectangle->minx<BR>\n";
echo "miny = $rectangle->miny<BR>\n";
echo "maxx = $rectangle->maxx<BR>\n";
echo "maxy = $rectangle->maxy<BR>\n";
// the following draw Mapserver does not like.
I cannot find any good examples how the draw for this rectobject should be
used.
$rectangle->draw();
the mapfile layer I want to use for displaying the rectObJect
LAYER
  NAME "Ce-141"
  TYPE polygon
  STATUS ON
  CLASS
    NAME "Ce-141"
    COLOR 253 132 115
    BACKGROUNDCOLOR 253 132 115
    SYMBOL 'circle'
    LABEL
      TYPE TRUETYPE
      ANTIALIAS FALSE
      FONT arial
      COLOR 0 0 0
      BACKGROUNDCOLOR 254 254 254
      SIZE 6
#      ANGLE 45
      POSITION uc
#      buffer 2
    END
  END
END
Content-Type: text/html;
	charset="US-ASCII"
Content-Transfer-Encoding: quoted-printable
<html>
<head>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Dus-ascii">
<meta name=3DGenerator content=3D"Microsoft Word 10 (filtered)">
<style>
 /* Style Definitions */
 p.MsoNormal, li.MsoNormal, div.MsoNormal
	{margin:0cm;
	margin-bottom:.0001pt;
	font-size:12.0pt;
	font-family:"Times New Roman";}
p.MsoBodyText, li.MsoBodyText, div.MsoBodyText
	{margin-top:0cm;
	margin-right:0cm;
	margin-bottom:6.0pt;
	margin-left:0cm;
	font-size:12.0pt;
a:link, span.MsoHyperlink
	{color:blue;
	text-decoration:underline;}
a:visited, span.MsoHyperlinkFollowed
	{color:purple;
p
	{margin-right:0cm;
	margin-left:0cm;
	font-size:12.0pt;
p.Opmaakprofiel1, li.Opmaakprofiel1, div.Opmaakprofiel1
	{margin:0cm;
	line-height:12.0pt;
	font-size:11.0pt;
span.EmailStijl19
	{font-family:Arial;
	color:windowtext;}
@page Section1
	{size:595.3pt 841.9pt;
	margin:72.0pt 90.0pt 72.0pt 90.0pt;}
div.Section1
	{page:Section1;}
</style>
</head>
<body lang=3DEN-GB link=3Dblue vlink=3Dpurple>
<div class=3DSection1>
<p class=3DMsoNormal><font size=3D2 face=3DArial><span =
style=3D'font-size:10.0pt;
font-family:Arial'>Hi all,</span></font></p>
font-family:Arial'> </span></font></p>
font-family:Arial'>I use Mapserver 4 with php =
mapscript</span></font></p>
font-family:Arial'>Here’s the thing,</span></font></p>
font-family:Arial'>I am trying to draw newRectObj() on a =
map.</span></font></p>
font-family:Arial'>The size and position are generated from =
mysql</span></font></p>
font-family:Arial'>However I think I am missing =
something.</span></font></p>
font-family:Arial'>What am I doing wrong here. I have been struggling =
with this
for a few days now, help would be higly appreciated.</span></font></p>
font-family:Arial'>Thanks,</span></font></p>
font-family:Arial'>Bart</span></font></p>
font-family:Arial'>// the map</span></font></p>
font-family:Arial'>$wvimap =3D =
ms_newMapObj("rdm3.map");</span></font></p>
font-family:Arial'>$wvimap->selectOutputFormat('png24');</span></font>=
</p>
font-family:Arial'>$wviimg =3D $wvimap->draw();</span></font></p>
font-family:Arial'>$imageobject =3D $wviimg->saveImage(test); =
</span></font></p>
font-family:Arial'>//  get correct layer</span></font></p>
font-family:Arial'>$wvilayer =3D =
$wvimap->getLayerByName("$bleble");</span></font></p>
font-family:Arial'>//$layerhandle =3D $wvilayer->open('$shpFname',1); =
</span></font></p>
font-family:Arial'>// Zoek in deze layer de eerste =
class</span></font></p>
font-family:Arial'>$classObj =3D =
$wvilayer->getClass(0);</span></font></p>
font-family:Arial'>echo "classobject =3D =
$classObj<br>\n";</span></font></p>
font-family:Arial'>$wvilayer->set("name", =
font-family:Arial'>$wvilayer->set (status,MS_ON);</span></font></p>
font-family:Arial'>$wvilayer->set =
(type,MS_POLYGON);</span></font></p>
(classitem,$classObj);</span></font></p>
(labelitem,"WVI");</span></font></p>
(data,"$shpFname");</span></font></p>
font-family:Arial'>$wvilayer->draw($wvimap,$classObj);</span></font></=
p>
font-family:Arial'>// Declaration of the rectangle =
object</span></font></p>
font-family:Arial'>$rectangle =3D ms_newRectObj();</span></font></p>
font-family:Arial'>// Here I calculate the values of the rectangle =
</span></font></p>
font-family:Arial'>$rectangle->set("minx",($hshift+($measure=
ments)*($rd_x)));</span></font></p>
font-family:Arial'>$rectangle->set("miny",(($vshift+($measur=
ements)*($rd_y))));</span></font></p>
font-family:Arial'>$rectangle->set("maxx",(($hshift+(($measu=
rements)*($rd_x)+($barwidth)))));</span></font></p>
font-family:Arial'>$rectangle->set("maxy",(($measurements)*(=
$rd_y)
(($maxbarheight/$maxvalue)*($measurements))+($barminheight)));</span></fo=
nt></p>
font-family:Arial'>echo "minx =3D =
$rectangle->minx<BR>\n";</span></font></p>
font-family:Arial'>echo "miny =3D =
$rectangle->miny<BR>\n";</span></font></p>
font-family:Arial'>echo "maxx =3D =
$rectangle->maxx<BR>\n"; </span></font></p>
font-family:Arial'>echo "maxy =3D =
$rectangle->maxy<BR>\n"; </span></font></p>
font-family:Arial'>// the following draw Mapserver does not =
like…</span></font></p>
font-family:Arial'>I cannot find any good examples how the draw for this =
rectobject
should be used.</span></font></p>
font-family:Arial'>$rectangle->draw();</span></font></p>
font-family:Arial'>the mapfile layer I want to use for displaying the =
rectObJect</span></font></p>
font-family:Arial'>LAYER</span></font></p>
font-family:Arial'>  NAME "Ce-141"</span></font></p>
font-family:Arial'>  TYPE polygon</span></font></p>
font-family:Arial'>  STATUS ON</span></font></p>
font-family:Arial'>  CLASS</span></font></p>
font-family:Arial'>    NAME =
font-family:Arial'>    COLOR 253 132 =
115</span></font></p>
font-family:Arial'>    BACKGROUNDCOLOR 253 132 =
font-family:Arial'>    SYMBOL 'circle'</span></font></p>
font-family:Arial'>    LABEL</span></font></p>
font-family:Arial'>      TYPE =
TRUETYPE</span></font></p>
font-family:Arial'>      ANTIALIAS =
FALSE</span></font></p>
font-family:Arial'>      FONT =
arial</span></font></p>
font-family:Arial'>      COLOR 0 0 =
0</span></font></p>
font-family:Arial'>      BACKGROUNDCOLOR 254 =
254 254</span></font></p>
font-family:Arial'>      SIZE =
6</span></font></p>
font-family:Arial'>#      ANGLE =
45</span></font></p>
font-family:Arial'>      POSITION =
uc</span></font></p>
font-family:Arial'>#      buffer =
2</span></font></p>
font-family:Arial'>    END</span></font></p>
font-family:Arial'>END</span></font></p>
<p><font size=3D3 face=3D"Times New Roman"><span =
style=3D'font-size:12.0pt'> </span></font></p>
</div>
</body>
</html>
------=_NextPart_000_0030_01C340C0.EFFB53F0--
More information about the MapServer-users mailing list
