[Mapserver-users] python mapscript
Sean Gillies
sgillies at frii.com
Wed Jul 2 12:06:43 EDT 2003
Michael,
I think this is probably an issue with MapServer's C library.
Am looking into it now to see what happens in msQueryByPoint.
I agree that msQueryByPoint should not raise an error in the
case of no records found by an otherwise proper query.
Another thing we could do is to evade the error in MapScript's
error handler like we are doing with the error that is raised
when no shapefile tileindex is present. Maybe this is the
best way for now, and push to change msQuery* behavior for
MapServer 4.1.
cheers,
Sean
On Wednesday, July 2, 2003, at 09:14 AM, Michael Schulz wrote:
> Hi,
> i have a question concerning the new error handling code in python
> mapscript. While it is very good that mapscript now throws real
> meaningful exceptions for a lot of errors, it is somewhat annyoing that
> e.g. queryByPoint also gives an error when no records where found. What
> would be the correct way to change this behaviour?
> A bit more background information why this behaviour is annoying me
> (for
> those using python mapscript in the zmapserver environment): i am
> working on implementing query mechanisms in zmapserver, and in the
> combination zope-zmapserver-python/mapscript it seems, that i am not
> able to catch this exception correctly. Even worse, the zope process
> gets killed (although an error should be raised, the zope process
> segfaults). Well, as you might assume this is not the intended
> behaviour. Hmm, any ideas, where to start looking?
> TIA, Michael
Sean Gillies
sgillies at frii dot com
http://www.frii.com/~sgillies
