[Mapserver-users] Oracle Spatial
Zamil Murji
Zamil.Murji at divestco.com
Wed Jul 2 14:03:19 EDT 2003
Hello list,
I want to use MapServer to draw an Oracle Spatial layer, however, I have never used Oracle Spatial. I have some questions I am sure you will be able to answer.
1) What utilities are available to import a shapefile into an Oracle Spatial database? Where can I download them from?
2) Need to know some good sites on how to setup Oracle 8i with the Spatial component, and I need a quick tutorial on how to create a table, alter a table, insert and select from that table. Any good sites?
3) I read on the newsgroup that there are two ways to go about this. One is to use the built in oracle spatial support and the other is to use ogr. I am running Apache on a windows 2000 box, what way is the best to go, easiest to setup?
Thanks for your help
Zamil
-----Original Message-----
From: Eduardo Patto Kanegae [mailto:eduardo at linkgeo.com.br]
Sent: Wednesday, June 25, 2003 8:44 AM
To: mapserver-users at lists.gis.umn.edu
Cc: niklas "wörmann
Subject: Re: [Mapserver-users] running v4 beta as a command line tool
I've tested on MapServer 3.6.4 for Windows, using:
$ mapserv "QUERY_STRING=map=c:\test\mymap.map&mode=map&foo=...." > myresult.gif
but if you try to open "myresult.gif" it crash...
so I opened this file with a text editor and deleted the first two lines(the headers), then it works!
regards
http://www.linkgeo.com.br
***Fim da Mensagem / End of Message ***
On Wed, 25 Jun 2003 14:43:41 +0200, Vincent Schut <schut at sarvision.com> enscreveu:
> De: Vincent Schut <schut at sarvision.com>
> Data: Wed, 25 Jun 2003 14:43:41 +0200
> Para: niklas wörmann <nwoe at privat.utfors.se>, <mapserver-users at lists.gis.umn.edu>
> Assunto: Re: [Mapserver-users] running v4 beta as a command line tool
> On Wednesday 25 June 2003 10:06, niklas wörmann wrote:
> > Hi!
> > i am trying to track down the reason mapserver isn´t working on my windows
> > 2000 server.
> > i remember seeing somewhere that it was indeed possible to run mapserver as
> > a command line tool, specifying a map file and an output file
> > anyone know the syntax for this?
> On linux:
> ./mapserv "QUERY_STRING=map=/path/to/your/mapfile.map&mode=map"
> This will output headers + image data to stdout (on linux). Probably on
> windows your executable is not named mapserv but something like mapserv.exe?
> And use \ instead of / I think.
> you cannot just save the output as image file because the headers are in the
> output too.
> But you can see if it outputs something (lots of ascii: image), or gives an
> error.
> To see the image: type in your browser:
> http://localhost/cgi-bin/mapserv?map=/path/to/your/mapfile.map&mode=map
> change / in path to \ if on windows?
> Regards,
> ______________________________________
> Vincent Schut
> Sarvision B.V.
> Wageningen, The Netherlands
> www.sarvision.com
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
