[Mapserver-users] Oracle Spatial
Zamil Murji Zamil.Murji at divestco.com
Wed Jul 2 13:36:12 PDT 2003
Thanks Bart for the quick reply...
I was able to convert my shapefiles into oracle spatial format using some tools on otn. Using those tools they insert NULL as the SRID. Will this cause grief? According to the WIKI you had to specify a SRID otherwise you got a mapserver error. Is this correct?
Is there any way to see what query mapserver will be running? Like a log file or something of the sort.
In the connection string, does service refer to the ip address?
Thanks in advance,
Zamil
-----Original Message-----
From: Bart van den Eijnden [mailto:bartvde at xs4all.nl]
Sent: Wednesday, July 02, 2003 12:22 PM
To: Zamil Murji; mapserver-users at lists.gis.umn.edu
Subject: Re: [Mapserver-users] Oracle Spatial
Hi Zamil,
otn (Oracle technology network) is the best site for Oracle information.
Oracle itself has a tool to import shapefiles into Oracle Spatial.
http://otn.oracle.com (you can register for free)
The easiest to use is the built-in Oracle Spatial support. To use the
support through OGR, you have to compile OGR against the Oracle client
library.
See also the mapserver wiki Oracle Spatial page:
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?OracleSpatial
Best regards,
Bart
On Wed, 2 Jul 2003 12:03:19 -0600, Zamil Murji <Zamil.Murji at divestco.com>
wrote:
> Hello list,
> I want to use MapServer to draw an Oracle Spatial layer, however, I have
> never used Oracle Spatial. I have some questions I am sure you will be
> able to answer.
> 1) What utilities are available to import a shapefile into an Oracle
> Spatial database? Where can I download them from? 2) Need to know some
> good sites on how to setup Oracle 8i with the Spatial component, and I
> need a quick tutorial on how to create a table, alter a table, insert and
> select from that table. Any good sites?
> 3) I read on the newsgroup that there are two ways to go about this. One
> is to use the built in oracle spatial support and the other is to use
> ogr. I am running Apache on a windows 2000 box, what way is the best to
> go, easiest to setup?
> Thanks for your help
> Zamil
> From: Eduardo Patto Kanegae [mailto:eduardo at linkgeo.com.br]
> Sent: Wednesday, June 25, 2003 8:44 AM
> To: mapserver-users at lists.gis.umn.edu
> Cc: niklas "wörmann
> Subject: Re: [Mapserver-users] running v4 beta as a command line tool
> I've tested on MapServer 3.6.4 for Windows, using:
> $ mapserv "QUERY_STRING=map=c:\test\mymap.map&mode=map&foo=...." >
> but if you try to open "myresult.gif" it crash...
> so I opened this file with a text editor and deleted the first two
> lines(the headers), then it works!
> regards
> http://www.linkgeo.com.br
> ***Fim da Mensagem / End of Message ***
> On Wed, 25 Jun 2003 14:43:41 +0200, Vincent Schut <schut at sarvision.com>
> enscreveu:
>> De: Vincent Schut <schut at sarvision.com>
>> Data: Wed, 25 Jun 2003 14:43:41 +0200
>> Para: niklas wörmann <nwoe at privat.utfors.se>,   <mapserver-
>> users at lists.gis.umn.edu>
>> Assunto: Re: [Mapserver-users] running v4 beta as a command line tool
>> On Wednesday 25 June 2003 10:06, niklas wörmann wrote:
>> > Hi!
>> > i am trying to track down the reason mapserver isn´t working on my
>> windows
>> > 2000 server.
>> > i remember seeing somewhere that it was indeed possible to run
>> mapserver as
>> > a command line tool, specifying a map file and an output file
>> > anyone know the syntax for this?
>> On linux:
>> ./mapserv "QUERY_STRING=map=/path/to/your/mapfile.map&mode=map"
>> This will output headers + image data to stdout (on linux). Probably on
>> windows your executable is not named mapserv but something like
>> mapserv.exe? And use \ instead of / I think.
>> you cannot just save the output as image file because the headers are in
>> the output too.
>> But you can see if it outputs something (lots of ascii: image), or gives
>> an error.
>> To see the image: type in your browser:
>> http://localhost/cgi-bin/mapserv?map=/path/to/your/mapfile.map&mode=map
>> change / in path to \ if on windows?
>> Regards,
>> -- ______________________________________
>> Vincent Schut
>> Sarvision B.V.
>> Wageningen, The Netherlands
>> www.sarvision.com
>> Mapserver-users mailing list
>> Mapserver-users at lists.gis.umn.edu
>> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
More information about the MapServer-users mailing list
