[Mapserver-users] adding RASTER Layer
Vincent Schut
schut at sarvision.com
Thu Jul 3 04:08:36 EDT 2003
Brock,
don't know if it helps, but you might try to recompile your mapserver with
--without-tiff to force it to use GDAL's tiff reading instead of libtiff.
GDAL's tiff reading capabilities extend the normal one with all kinds of
geotiff features, etc.
Cheers,
Vincent.
On Wednesday 02 July 2003 21:50, Brock Murch wrote:
> Dylan:
> Thanks, but no luck. Whether I comment out the #OFFSITE line, or put in
> OFFSITE 0 0 0 still gives me no image other that the vertival border I
> spoke of earlier.
> Brock
> On Wednesday 02 July 2003 3:42 pm, Dylan Keon wrote:
> > Brock,
> > Syntax for OFFSITE changed in 4.0. OFFSITE now takes an RGB value
> > instead of a single class index value. So, for example, if you're
> > trying to make black pixels transparent you would now use "OFFSITE 0 0
> > 0" instead of "OFFSITE 0" (assuming class 0 was assigned to black
> > pixels).
> > You could first try commenting out just the OFFSITE line to see if you
> > get anything...
> > --Dylan
> > Brock Murch wrote:
> > > Lo all:
> > > I seem to have stumbled into a problem. I am working throught the
> > > tutorial and have had much success, however, I can't seem to make the
> > > s2ex3 raster layer work. If I comment out the:
> > > #LAYER # Shaded Relief Raster
> > > # NAME "relief"
> > > # DATA "raster/shdrlfi020g_ugl.tif"
> > > # STATUS DEFAULT
> > > # TYPE RASTER
> > > # OFFSITE 0
> > > #END
> > > it works fine.
> > > However, if the layer is place I get no image, just a small vertical
> > > line (probably the border). I am using the newest version of mapserver.
> > > mapserv -v
> > > MapServer version 4.0-beta1 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> > > SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
> > > SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT INPUT=TIFF INPUT=EPPL7
> > > INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> > > gdal-config --formats
> > > gxf gtiff hfa aigrid aaigrid ceos ceos2 iso8211 bsb xpm sdts raw dted
> > > mem jdem envisat elas fit vrt usgsdem l1b nitf bmp hdf4 gif jpeg png
> > > I have tried it with my own data too. png format with a png world file
> > > following the above map file format with the same results.
> > > What am I missing? I'm not sure what to try next. Any thoughts would be
> > > greatly appreciated.
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
______________________________________
Vincent Schut
Sarvision B.V.
Wageningen, The Netherlands
www.sarvision.com
