[Mapserver-users] PHPmapscript 4, color
Dylan Keon
keon at nacse.org
Thu Jul 3 14:29:22 PDT 2003
Erich,
Check out the Migration Guide page on the Wiki. There are examples of
color handling, as well as other changes to make when moving from 3.5 to
4.0. http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?MigrationGuide
This should help (copied from the Wiki page):
Most class parameter definitions are now handled by the new style
object.
For example,
$classObj->set('color', $map->addColor(255,255,0));
$classObj->set('size', 18);
is now implemented as
$style = ms_newStyleObj($classObj);
$style->color->setRGB(255,255,0);
$style->set('size', 18);
--Dylan
Erich Schroeder wrote:
> Hi,
> I'm confused in how I should be rewriting some phpmapscript for changing
> from version 3.5 to 4.
> In my application it looks to see if a polygon shapefile showing modern
> distribution of a taxon exists, and if so adds it as a layer. It then
> checks to see if the user wanted it to show, and if not turns the layer
> off.
> The old script looks like:
> //Check if modern distribution is present, and add
> if (file_exists("mammal/$TaxonLower.shp")) {
> $distpresent = TRUE;
> $layer = ms_newLayerObj($map);
> $layer->set("data","mammal/$TaxonLower");
> $layer->set("name","moderndist");
> $layer->set("type",MS_LAYER_POLYGON);
> $layer->set("status",MS_ON);
> if ($drawdist == "n") {$layer->set("status",MS_OFF);}
> $distcolor = $map->addColor(232,151,97);
> $class = ms_newClassObj($layer);
> $class->set("name","ModernDistribution");
> $class->set("symbol",0);
> $class->set("color",$distcolor);
> $ok = $map->moveLayerUp(3);
> $img = $map->draw();
> } //end of modern dist
> And now of course it chokes on the
> line.
> Am I supposed to now have a line like:
> $class->setRGB(232,151,97);
> Erich
More information about the MapServer-users
