[Mapserver-users] Re: Gmap under mapserver 4
Yewondwossen Assefa
assefa at dmsolutions.ca
Fri Jul 4 10:30:47 EDT 2003
Try to do $oLayer->open() with no argument. This changed between 3.6 and
4.0.
Later
Bart van Heijningen wrote:
>Hi,
>I wonder if anyone here can help me with the next question.
>I am using mapserver 4 and try to get the gmap demo to work. All seems
>fine but I cannot seem to be able to get the querying right.
>It simply does not work.
>Maybe someone knows what the problem is?
>Somehow it no longer seems to be happy with the dbf file under
>Mapserver4.
>Looks like it does not like the amount of return fields from the query.
>Error:
>Warning: Wrong parameter count for open() in
>/www/htdocs/atmspoc/htdocs/poc_gmap75.php on line 698
>Fatal error: MapServer Error in msLayerGetShape(): Shapefile layer has
>not been opened. in /www/htdocs/atmspoc/htdocs/poc_gmap75.php on line
>729
>Here is the gmap file the last line ¨$oLayer->open($gpoMap->shapepath);¨
>produces the error.
> for($iLayer=0; $iLayer < $gpoMap->numlayers; $iLayer++)
> $oLayer = $gpoMap->GetLayer($iLayer);
> $numResults = $oLayer->getNumResults();
> if ($numResults == 0)
> continue; // No results in this layer
> // Open layer's table... take the list of fields to display
>from
> // the "HEADERRESULT_FIELDS" metadata in the layer object.
> $selFields = explode(" ",
>$oLayer->getMetaData("RESULT_FIELDS"));
>Thanks,
>Bart
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
