[Mapserver-users] Problem with Perl Mapscript
Lowell Filak
lfilak at medinaco.org
Mon Jul 7 10:45:06 EDT 2003
I don't see anything in the provided code aside from the previously sent
comments and a missing "form" for the html "input".
Is the routine now working or is there another error occurring?
Lowell
The following message was sent by AMC Story <s9646183 at sms.ed.ac.uk> on
Thu, 03 Jul 2003 12:41:52 +0100 (BST).
> Hi everyone,
> Following my question about using JavaScript/MapScript to develop the
standard
> MapServer interface, I've now decided to try to use both, and have got
the Perl
> MapScript module working on our apache server.
> My problem is that most of the documentation and examples are for PHP
> MapScript. Having only a list of constructors/methods etc for each
object type
> is helpful to a point, but this doesn't tell me how I should be
putting them
> together to get something to actually work! I've been trying to
convert the
> PHP MapScript by Example HOWTO into perl, using Steve Lime's
mapquakes.pl as a
> guide.
> My first problem is that perl mapscript doesn't seem to have a direct
> equivalent of the saveWebImage method. Is this correct? In the
absence of
> such a method, I've been trying to use the saveImage method, but here
I seem to
> be running into problems. If you look at the way I've called the
method (see
> code below), then maybe you could suggest what I'm doing wrong.
> In the first case (ie. using mapscript::msSaveImage(...)), I get the
error
> message "Type error in argument 1 of msSaveImage. Expected
_p_gdImagePtr..."
> when I run the program at the command line. In the second case, using
$image-
> >saveImage(..), I get the following usage message "Usage:
imageObj_saveImage
> (self,filename,type,transparent,interlace,quality);". This has
confused me
> because this isn't the argument list given in the documentation.
> If anyone has some simple, step by step examples of how to build up
> applications using Perl MapScript I'd be really interested in having a
look.
> Many thanks,
> Ali
> #!/usr/local/bin/perl -w
> #playing around with mapscript
> #use mapscript;
> use CGI qw(:standard);
> use mapscript;
> $cgi = new CGI;
> $map_file = "/usr/local/apache/local-bin/s9646183/mapscript/quakes.map";
> $image_path = "/usr/local/apache/htdocs/tmp/";
> $image_url = "/tmp/";
> $image_id = $$ . time() . ".png";
> $map = new mapscript::mapObj($map_file);
> $image = $map->prepareImage();
> $layer = $map->getLayerByName('countries');
> $layer->draw($map, $image);
> mapscript::msSaveImage($image, $image_path.$image_id,
$map->{imagetype}, $map->
> {transparent}, $map->{interlace}, $map->{imagequality});
> #$image->saveImage($image, $image_path.$image_id, $mapscript::MS_PNG,
$map->
> print $cgi->header();
> print $cgi->start_html(-title=>'Map 1: Perl Mapscript Test');
> print "<p>This is just a test</p>";
> print "<center><input type=\"image\" name=\"map\"
src=\"". $image_url .
> $image_id ."\"><br>";
> print $cgi->end_html();
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
