AW: [Mapserver-users] queries - mapserver is "hanging"
Christina Biakowski CCGIS
christina.biakowski at ccgis.de
Wed Jul 9 09:51:40 EDT 2003
We are using 3.6.4, I'll try a newer version.
Thanks, Christina
-----Ursprungliche Nachricht-----
Von: mapserver-users-admin at lists.gis.umn.edu
[mailto:mapserver-users-admin at lists.gis.umn.edu]Im Auftrag von Daniel
Morissette
Gesendet: Mittwoch, 9. Juli 2003 15:26
An: Christina Biakowski (CCGIS)
Cc: Mapserver-Users at Lists. Gis. Umn. Edu
Betreff: Re: [Mapserver-users] queries - mapserver is "hanging"
Are you using the latest 3.6.6? There was a similar problem if I
remember well that was fixed somewhere between 3.6.0 and 3.6.6. That
may or may not be the same thing that you ran into.
If you have a systematic way to reproduce this with 4.0 as well then I
would suggest that you file a bug in bugzilla with a mapfile and sample
layer data, and steps to reproduce. If you use a precompiled windows
binary then please also specify where you got it (URL) in the bug.
Daniel
"Christina Biakowski (CCGIS)" wrote:
> Hello,
> we have problems with MapServer, when in quick succession query-requests
> (using GetFeatureInfo) are set. After some requests performance is
> decreasing significantly and we even got CGI-timeouts. Having a look at
the
> processes on the server I found that with every request a
mapserver-process
> is started. The process then is still running quite a while after the
> query-request has been send, e.g. after many requests many
> MapServer-processes are running simultaneously until the queries do not
work
> any more. I wonder why it takes so long until the mapserv-process stops,
> after a query has been passed to MapServer. What might be the problem?
> (We are using 3.6 on Windows)
> Thanks!
> Regards,
> Christina
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
