[Mapserver-users] Perl Mapscript - equivalent of zoompoint
method..?
Eric Bridger
eric at gomoos.org
Thu Jul 10 09:44:41 EDT 2003
Ali,
In the Wiki, mapquakes.pl example:
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?PerlMapScriptExamples35ex2 there is a function called set_extent() which takes the users mouse click and zooms the map to that point. Is that what you need?
If no zoom is set, $zoom_dir == 0, then this functions as a pan tool, recentering the map.
Steve Lime wrote mapquakes.pl. I also adapted some javascript of his into Perl to handle pan direction buttons. This just adjusts the mouse click image coordinates which then must be passed to set_exent().
sub pan_to_map {
my ($map, $direction) = @_;
my $pansize = .50;
my ($x, $y) = (0,0);
my $width = $map->{width};
my $height = $map->{height};
if($direction eq 'n') {
$x = ($width-1)/2.0;
$y = 0 - ($height * $pansize)/2.0;
} elsif($direction eq 'nw') {
$x = 0 - ($width * $pansize)/2.0;
} elsif($direction eq 'ne') {
$x = ($width-1) + ($width * $pansize)/2.0;
} elsif($direction eq 's') {
$y = ($height-1) + ($height * $pansize)/2.0;
} elsif($direction eq 'sw') {
} elsif($direction eq 'se') {
} elsif($direction eq 'e') {
$y = ($height-1)/2.0;
} elsif($direction eq 'w') {
$x = int($x);
$y = int($y);
return($x, $y);
Eric
At 12:37 PM 07/10/2003 +0100, AMC Story wrote:
>Hi there everyone,
>I'm using Perl Mapscript to develop the interface of my application, and have
>very kindly been given some existing code to work from from another member of
>the list. The code that I am making reference to is written using PHP
>Mapscript, so I'm having a little bit of trouble in that not all of the methods
>available with PHP Mapscript are available with the Perl version.
>I'm dealing with my panning buttons at the moment, and the example I have
>defines a point object which the new map will zoom to, and then uses the
>zoompoint method of the map object. This method isn't available in Perl, does
>anyone have any suggestions as to how I might get around this? Similarly,
>their zoomin function makes use of the zoomrectangle method...
>Thanks for any light you can shed on this.
>Ali
>_______________________________________________
>Mapserver-users mailing list
>Mapserver-users at lists.gis.umn.edu
>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
