[Mapserver-users] automatically resize
Charlton Purvis
cpurvis at asg.sc.edu
Fri Jul 11 09:44:43 EDT 2003
Hey, Eric:
I'm having a booger of a time getting my symbols to resize w/ zooming.
Given your example, how does the SYMBOLSCALE number relate to your MAP
level SCALE (min and max)? I'm also assuming that the circle and the
text label increase at the same rate w/ a zoom. Is that right?
In my case, I am only interested in keeping my point layer connected.
So at the initial scale (133277), a size of 1 for a SYMBOL 4 (square) is
fine. When I'm zoomed in (SCALE = 4999) my square points need to appear
much bigger so that they will appear connected.
Am I on the right track?
Thanks.
-----Original Message-----
Sent: Friday, April 11, 2003 7:18 AM
To: Jehng-Jung Kao
Cc: Mapserver List
Subject: Re: [Mapserver-users] automatically resize
You can use SYMBOLSCALE in a LAYER in your map file which works with
both CLASS MINSIZE, MAXSIZE and LABEL MINSIZE MAXSIZE to scale both the
symbol and text. You'll need to use truetype fonts and play around with
the SYMBOLSCALE value which changes with the zoom-in/out.
Here's an example:
LAYER
NAME "cities"
TYPE POINT
DATA "/mapserver/data/vector/tiger/cities"
STATUS DEFAULT
LABELITEM "PLACE"
SYMBOLSCALE 1320000
CLASS
NAME "City"
SYMBOL "circle"
COLOR 255 255 0
OUTLINECOLOR 0 0 0
SIZE 8
LABEL
TYPE TRUETYPE
FONT helr
SIZE 9
COLOR 0 0 0
ANTIALIAS TRUE
POSITION AUTO
PARTIALS FALSE
MAXSIZE 13
MINSIZE 8
END
END
END
On Fri, 2003-04-11 at 03:08, Jehng-Jung Kao wrote:
> Dear List,
> Is there any way to resize label based on the display size
(zoom-in/out)
> instead of a fixed size?
> Jehng-Jung Kao
> | Jehng-Jung Kao, Professor Email: jjkao at ensys.ev.nctu.edu.tw
> | Inst. of Environ. Engrg. Tel/Fax: +886-3-5731869/5731759
> | National Chiao Tung Univ., 75 Po-Ai St., Hsinchu, Taiwan 30090, ROC.
> | http://green.ev.nctu.edu.tw/~jjkao
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
