[Mapserver-users] mapserver 4.0b configuration error and php 4.3.2 (regex again)
Pete Schmitt
pete at crrel.usace.army.mil
Fri Jul 11 09:09:37 PDT 2003
--------------000608010203080709000803
Content-Type: text/plain; charset=us-ascii; format=flowed
Content-Transfer-Encoding: 7bit
I have php configured with the following:
--with-mysql=/usr --with-apxs=/usr/local/$APACHE/bin/apxs \
--enable-track-vars --enable-dbase --with-oci8=$ORACLE --enable-trans-sid \
--with-regex=system --enable-magic-quotes --with-gd --with-zlib \
--enable-sigchild --with-freetype-dir=/usr --enable-gd-native-ttf
...when I run configure with the following on mapserver-4.0b:
--without-jpeg --with-gd=../gd-2.0.12gif \
--with-freetype --with-zlib --with-png \
--with-pdf --without-tiff --without-eppl --with-proj \
--with-sde=/usr/local --with-sde-version=82 \
--with-ogr --with-gdal=../gdal-1.1.9/apps/gdal-config \
--with-oraclespatial=$ORACLE_HOME \
--with-php=../php-4.3.2/ \
--with-wmsclient --with-wfsclient \
--with-wfs --enable-debug
I get this error:
configure: error:
!!! The current version of PHP MapScript has some problems with !!!
!!! PHP4's bundled regex. Until we figure the solution to the !!!
!!! problem, the workaround is to compile PHP4 with the system regex !!!
!!! Please re-configure and re-compile PHP4 with --with-regex=system !!!
!!! and then re-configure and re-compile MapServer. !!!
What am I missing?
Content-Type: text/html; charset=us-ascii
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<title></title>
</head>
<body>
I have php configured with the following:<br>
<br>
<tt>--with-mysql=/usr --with-apxs=/usr/local/$APACHE/bin/apxs \<br>
\<br>
<b>--with-regex=system </b>--enable-magic-quotes --with-gd --with-zlib \<br>
--enable-sigchild --with-freetype-dir=/usr --enable-gd-native-ttf</tt><br>
<br>
...when I run configure with the following on mapserver-4.0b:<br>
<br>
<tt>--without-jpeg --with-gd=../gd-2.0.12gif \<br>
--with-freetype --with-zlib --with-png \<br>
--with-pdf --without-tiff --without-eppl --with-proj \<br>
--with-sde=/usr/local --with-sde-version=82 \<br>
--with-ogr --with-gdal=../gdal-1.1.9/apps/gdal-config \<br>
--with-oraclespatial=$ORACLE_HOME \<br>
<b>--with-php=../php-4.3.2/</b> \<br>
--with-wmsclient --with-wfsclient \<br>
--with-wfs --enable-debug</tt><br>
<br>
I get this error:<br>
<br>
<b><tt>configure: error: <br>
!!! The current version of PHP MapScript has some problems with !!!<br>
!!! PHP4's bundled regex. Until we figure the solution to the !!!<br>
!!! problem, the workaround is to compile PHP4 with the system regex !!!<br>
!!! Please re-configure and re-compile PHP4 with --with-regex=system !!!<br>
!!! and then re-configure and re-compile MapServer. !!!</tt></b><br>
<br>
What am I missing?<br>
<br>
<br>
<br>
</body>
</html>
--------------000608010203080709000803--
More information about the MapServer-users
