[Mapserver-users] Graticule problems at large scales
William K
woklist at charter.net
Fri Jul 11 17:43:32 EDT 2003
Finaly got around to playing with the graticule feature in the 4.0
beta. Works fine up to a point - when zooming in to a large scale, the
starting point gets out of sync with the interval. ie, if I have a 15
minute (0.25 degree) interval, when I get to about 1:500,000 scale
(with a Lambert Conic projection), I start to get grid lines at places
like 14, 29, 44 & 59 minutes instead of the 0, 15, 30 & 45 I want and
expect. And at the same scale the starting point varies depending on
where I pan to.
If this is some adjustment of the starting point to get an even or
minimum distribution of grid lines in the map, I'd still rather have a
fixed starting point (ie at some multiple of the interval) and adjust
the LAYER's MIN/MAX-SCALE and the GRID's MIN/MAX-INTERVAL myself.
Another issue with the graticule (and possibly related) - when I start
using a third decimal place for intervals, such as 0.125 for 7.5
minutes, the grid labels start to get odd rounding errors. For a 0.125
interval using the DDMMSS label format, some labels have the correct 00
and 30 seconds, while other have 59 and 29 seconds, on the same map.
William Kyngesburye <kyngchaos at charter.net>
http://webpages.charter.net/kyngchaos/
"This is a question about the past, is it? ... How can I tell that the
past isn't a fiction designed to account for the discrepancy between my
immediate physical sensations and my state of mind?"
- The Ruler of the Universe
RIP Douglas Adams 1952-2001
