[Mapserver-users] Python/Mapscript
Norman Vine
nhv at cape.com
Sat Jul 12 15:54:02 EDT 2003
Sean Gillies writes:
> On Saturday, July 12, 2003, at 11:53 AM, Heitzso wrote:
> > I followed the directions at
> > http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?PythonMapScript
> > to build the python mapscript module.
> Heitzso,
> Please disregard the directions on the Wiki page. They are a bit
> out of date. Here is the official recipe to compile Python
> MapScript.
> 1. Download and compile the latest nightly (pre-4.0) MapServer.
> This is important because it will allow you to pick up some
> important changes made to the mapscript wrappers since the
> 4.0beta1 release was made.
> 2. cd into the mapscript/python directory
> 3. execute "python setup.py install". That's it.
Hmm there seems to be a problem ....
< This is with CVS files >
mapscript_wrap.c: In function `mapObj_processQueryTemplate':
mapscript_wrap.c:1652: warning: passing arg 2 of `msProcessQueryTemplate' makes integer from pointer without a cast
mapscript_wrap.c:1652: warning: passing arg 4 of `msProcessQueryTemplate' makes pointer from integer without a cast
mapscript_wrap.c:1652: too few arguments to function `msProcessQueryTemplate'
< cheap hack to get mapscript to compile is >
$ cvs diff mapscript.i
Index: mapscript.i
RCS file: /data2/cvsroot/mapserver/mapscript/mapscript.i,v
retrieving revision 1.113
diff -r1.113 mapscript.i
397c397,398
< return msProcessQueryTemplate(self, names, values, numentries);
> // return msProcessQueryTemplate(self, names, values, numentries);
> return msProcessQueryTemplate(self, 0, names, values, numentries);
> If MapServer was built properly, the newest setup.py script will
> find all the required libraries for you.
FYI - This new script does *not* work for me
For anyone else on a unix like system who is having problems building
python mapscript I keep the files I use at
http://www.vso.cape.com/~nhv/files/python/mapscript.html
Cheers
Norman
