AW: [Mapserver-users] landsat wms
Arnulf Christl CCGIS
arnulf.christl at ccgis.de
Mon Jul 14 10:22:41 EDT 2003
we also had a problem loading that service. We analysed the capabilities
document and found that the BBox of the root layer is not defined. We have
added it (as can be seen in the attached XML) and for us it works now. Maybe
UMN MapServer has the same problem as we had?!
Regards, Arnulf.
-----Ursprüngliche Nachricht-----
Von: mapserver-users-admin at lists.gis.umn.edu
[mailto:mapserver-users-admin at lists.gis.umn.edu]Im Auftrag von
Swaminathan, Gayathri
Gesendet: Samstag, 12. Juli 2003 23:16
An: 'Aaron D. Hunt'
Cc: 'mapserver-users at lists.gis.umn.edu'
Betreff: RE: [Mapserver-users] landsat wms
Hi:
Tried the following but it does not seem to work for me. I have the exact
code segment below, in my map file.
So I went to http://wms.jpl.nasa.gov and they seem to use a landsat.cgi to
get to their landsat map.,?
I am not sure if I am doing something wrong.
Thanks,
Gayathri
-----Original Message-----
Sent: Wednesday, July 09, 2003 3:11 PM
To: Gerry Creager N5JXS
Cc: mapserver-users at lists.gis.umn.edu
Subject: Re: [Mapserver-users] landsat wms
Here is the layer needed to display the landsat
LAYER
NAME LandSat
METADATA
"wms_title" "LandSat"
"wms_srs" "EPSG:4326" #WGS 84
"wms_extent" "-78 0 -72 90"
LYRNAME "LandSat"
LINK "N/A"
END
OFFSITE 255 255 255
GROUP "LandSat DATA"
STATUS ON
TYPE RASTER
CONNECTIONTYPE WMS
CONNECTION
"http://wms.jpl.nasa.gov/wms.cgi?WMTVER=1.0.0&REQUEST=map&LAYERS=us%5Flandsa
t7&STYLES=&FORMAT=PNG&TRANSPARENT=TRUE&"
PROJECTION
"init=epsg:4326" #WGS 84
END
END
----- Original Message -----
From: "Gerry Creager N5JXS" <gerry.creager at tamu.edu>
To: "Aaron D. Hunt" <hunt at zedxinc.com>
Sent: Wednesday, July 09, 2003 3:09 PM
> If you get it, could I ask for a copy for Texas Mesonet?
> TIA, gerry
> Aaron D. Hunt wrote:
> > Does anyone have an example Layer of using JPL's WMS landsat server.
> > Aaron D. Hunt Technical Manager
> > ZedX Inc.
> > Voice: 814-357-8490
> > Fax: 814-357-8499
> Gerry Creager -- gerry.creager at tamu.edu
> Network Engineering -- AATLT, Texas A&M University
> Cell: 979.229.5301 Office: 979.458.4020 FAX: 979.847.8578
> Page: 979.228.0173
> Office: 903A Eller Bldg, TAMU, College Station, TX 77843
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
