[Mapserver-users] landsat wms
Swaminathan, Gayathri
gayathri at ou.edu
Mon Jul 14 10:25:09 EDT 2003
Hello:
Thanks Aaron and Arnulf,
I had to give, "Bbox" at the end of the connection string,
CONNECTION
"http://wms.jpl.nasa.gov/wms.cgi?WMTVER=1.0.0&REQUEST=map&LAYERS=LandSat&STY
LES=&FORMAT=PNG&TRANSPARENT=TRUE&BBox=499000,4499000,500000,4500000"
And it seems to work.
Thanks,
Gayathri
-----Original Message-----
From: Arnulf Christl (CCGIS) [mailto:arnulf.christl at ccgis.de]
Sent: Monday, July 14, 2003 8:23 AM
To: Swaminathan, Gayathri; 'Aaron D. Hunt'
Cc: mapserver-users at lists.gis.umn.edu
Subject: AW: [Mapserver-users] landsat wms
we also had a problem loading that service. We analysed the capabilities
document and found that the BBox of the root layer is not defined. We have
added it (as can be seen in the attached XML) and for us it works now. Maybe
UMN MapServer has the same problem as we had?!
Regards, Arnulf.
-----Ursprüngliche Nachricht-----
Von: mapserver-users-admin at lists.gis.umn.edu
[mailto:mapserver-users-admin at lists.gis.umn.edu]Im Auftrag von Swaminathan,
Gayathri
Gesendet: Samstag, 12. Juli 2003 23:16
An: 'Aaron D. Hunt'
Cc: 'mapserver-users at lists.gis.umn.edu'
Betreff: RE: [Mapserver-users] landsat wms
Hi:
Tried the following but it does not seem to work for me. I have the exact
code segment below, in my map file.
So I went to http://wms.jpl.nasa.gov and they seem to use a landsat.cgi to
get to their landsat map.,?
I am not sure if I am doing something wrong.
Thanks,
Gayathri
