[Mapserver-users] Mapserver 4.0b2 make errors
Steve Lime
steve.lime at dnr.state.mn.us
Mon Jul 14 14:15:42 PDT 2003
The majority of these are benign unless you're playing with image map
output. I'll forward these to the developers list so folks can clean
things up.
Steve
>>> Fido <fidofla at yahoo.com> 07/14/03 02:52PM >>>
Using Redhat 9, PHP 4.3.2, Apache 1.3.27, Mapserver
4.0b2 when running make I get the following errors:
mapprimitive.c:1147: warning: unused variable `s'
mapprimitive.c:1147: warning: `drawpoly' might be used
uninitialized in this function
mapprimitive.c:1442: warning: unused variable `buffer'
mappostgis.c:1010: warning: enumeration value
`MS_LAYER_GRATICULE' not handled in swi
tch
mappostgis.c:1213: warning: enumeration value
tch
maplayer.c:629: warning: unused variable `i'
mapdraw.c:245: warning: implicit declaration of
function `msDrawWMSLayerSWF'
mapdraw.c:1425: warning: passing arg 1 of
`msDrawTextIM' from incompatible pointer ty
pe
mapgd.c:278: warning: `dx0' might be used
mapgd.c:278: warning: `ox' might be used uninitialized
in this function
mapgd.c:278: warning: `oy' might be used uninitialized
in this function
mapgd.c:279: warning: `x0' might be used uninitialized
in this function
mapgd.c:279: warning: `y0' might be used uninitialized
in this function
mapgd.c:279: warning: `k' might be used uninitialized
in this function
mapgd.c:279: warning: `k0' might be used uninitialized
in this function
mapgd.c:279: warning: `q' might be used uninitialized
in this function
mapgd.c:279: warning: `q0' might be used uninitialized
in this function
mapgd.c:1245: warning: `oldAlphaBlending' might be
used uninitialized in this functio
n
mapswf.c:2049: warning: unused variable `classPtr'
mapimagemap.c:59: warning: `searchImageCache' defined
but not used
mapimagemap.c:89: warning: `addImageCache' defined but
not used
mapimagemap.c:333: warning: `imageOffsetPolyline'
defined but not used
mapimagemap.c:364: warning: `imagePolyline' defined
but not used
mapimagemap.c:1392: warning: `billboardIM' defined but
not used
mapcopy.c:916: warning: unused variable `szPath'
php_mapscript.c:11447: warning: assignment discards
qualifiers from pointer target ty
pe
php_mapscript.c:11529: warning: implicit declaration
of function `initGrid'
__________________________________
Do you Yahoo!?
SBC Yahoo! DSL - Now only $29.95 per month!
http://sbc.yahoo.com
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
More information about the MapServer-users
