[Mapserver-users] Mapserver Bug
Zamil Murji
Zamil.Murji at divestco.com
Mon Jul 14 18:52:29 EDT 2003
Hi Randy and company,
No i don't think i need tileitem because i am using the default of 'location'. I repeat that the first tiled layer shows up but the ones underneath it do not.
Thanks
Zamil
-----Original Message-----
Sent: Monday, July 14, 2003 4:48 PM
To: Zamil Murji
Cc: Mapserver-users at lists.gis.umn.edu
Subject: Re: [Mapserver-users] Mapserver Bug
Hi
Looks like you need the TILEITEM in your mapfile
It is the column that has the location of the tile in it
Cheers
--- Zamil Murji <Zamil.Murji at divestco.com> wrote:
> Hi Steve and the rest of the list,
> I found a bug with regards to mapserver and tiled polygon
> layers. It seems that mapserver only displays the first
> tiled polygon layer in the .map file and doesn't show the
> tiled polygon layers below it. All other layers show up
> just fine below the first tiled polygon layer.
> I've attached two images. One with the tile county layer
> showing (above the township grid) and another with the
> township gird showing (above the county layer).
> Here are the two layer defs, please tell me if i'm
> missing something obvious:
> LAYER
> NAME "counties"
> TILEINDEX us_data/culture/countytileindex
> STATUS off
> TYPE POLYGON
> CLASS
> OUTLINECOLOR 0 0 0
> end
> end
> LAYER
> NAME "twp"
> TILEINDEX us_data/townships/twptileindex
> STATUS off
> TYPE POLYGON
> # MAXSCALE 25
> CLASS
> OUTLINECOLOR 183 178 178
> #OUTLINECOLOR 255 0 0
> END
> END
> Zamil
> Mapserver-users mailing list
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
__________________________________
Do you Yahoo!?
SBC Yahoo! DSL - Now only $29.95 per month!
http://sbc.yahoo.com
