[Mapserver-users] terraserver problem
    Yewondwossen Assefa
    assefa at dmsolutions.ca
    Tue Jul 15 08:28:09 PDT 2003
--------------000204080707070600040609
Content-Type: text/plain; charset=us-ascii; format=flowed
Content-Transfer-Encoding: 7bit
Could it be that the server is generaing an exception (instead of an
image) when asked to generate maps at certain resolution/BBox ?  You
could generate a GetMap request to the server with approximatlty the
same bbox that you use in the Mapserver when the error occurs and see
what the server returns.
Later,
Aaron D. Hunt wrote:
> I am using the terraserver to zoom in to draw on a map. With wms, if
> the user zooms in where the image would be less the 1m (ie the size of
> the image at 1m is smaller then the image requested) mapserver gives
> the following error
> Tue Jul 15 10:36:44 2003 - msDrawMap(): Image handling error. Failed
> to draw layer named 'ortho-18'.
> Tue Jul 15 10:37:54 2003 - drawEPP(): Image handling error.
> /home/httpd/html/dy_images/105827987219400.img.tmp is not an EPPL file.
> Tue Jul 15 10:37:54 2003 - msDrawRaster(): Image handling error.
> Unrecognized or unsupported image format
> Is there anyway to let the userer zoom in to less then 1m?
> Aaron D. Hunt
> Technical Manager
> ZedX Inc.
> Voice: 814-357-8490
> Fax:    814-357-8499
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
Content-Type: text/html; charset=us-ascii
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
  <meta http-equiv="Content-Type" content="text/html;charset=ISO-8859-1">
  <title></title>
</head>
<body>
Could it be that the server is generaing an exception (instead of an image)
when asked to generate maps at certain resolution/BBox ?  You could generate
a GetMap request to the server with approximatlty the same bbox that you
use in the Mapserver when the error occurs and see what the server returns.<br>
<br>
Later,<br>
<br>
Aaron D. Hunt wrote:<br>
<blockquote type="cite"
 cite="mid006401c34ae1$0dcecea0$1805000a at helicity">
  <meta http-equiv="Content-Type" content="text/html; ">
  <meta content="MSHTML 6.00.2800.1170" name="GENERATOR">
  <style></style>
  <div><font face="Arial" size="2">I am using the terraserver to zoom in
to draw on a  map. With wms, if the user zooms in where the image would be
less the 1m (ie the  size of the image at 1m is smaller then the image requested)
mapserver gives the  following error </font></div>
  <div> </div>
  <div><font face="Arial" size="2">Tue Jul 15 10:36:44 2003 - msDrawMap():
Image  handling error. Failed to draw layer named 'ortho-18'.<br>
Tue Jul 15 10:37:54  2003 - drawEPP(): Image handling error.  /home/httpd/html/dy_images/105827987219400.img.tmp
is not an EPPL file.<br>
Tue  Jul 15 10:37:54 2003 - msDrawRaster(): Image handling error. Unrecognized
or  unsupported image format<br>
  </font></div>
  <div><font face="Arial" size="2">Is there anyway to let the userer zoom
in to less  then 1m?</font></div>
  <div><font face="Arial" size="2"> </font></div>
  <div> </div>
  <div><font face="Arial" size="2">Aaron D. Hunt<br>
Technical Manager<br>
ZedX  Inc.<br>
Voice: 814-357-8490<br>
Fax:     814-357-8499</font></div>
</blockquote>
<br>
<pre class="moz-signature" cols="$mailwrapcol">--
Assefa Yewondwossen
Software Analyst
Email: <a class="moz-txt-link-abbreviated" href="mailto:assefa at dmsolutions.ca">assefa at dmsolutions.ca</a>
<a class="moz-txt-link-freetext" href="http://www.dmsolutions.ca/">http://www.dmsolutions.ca/</a>
Fax:   (613) 565-0925
</pre>
<br>
</body>
</html>
--------------000204080707070600040609--
More information about the MapServer-users
