Mapscript Bug? (was Re: [Mapserver-users] map drop shadow effect)
Yewondwossen Assefa assefa at dmsolutions.ca
Tue Jul 15 11:55:33 PDT 2003
I am gettting the same relult with a multiple styles and the shadow
effect. I have entered a Bug 346 on this.
Stephen, did this work for you ?
Later,
Dan Barron wrote:
> Hi Dan,
> Since DM Solutions is the keeper of PHP/Mapscript, I thought I'd pass
> this along.
> In trying to use the STYLES with v4.0b2 PHP/Mapscript and SHP files to
> achieve a drop shadow effect, only the final STYLE COLOR actually
> fills within the polygon. So using the following:
> class
> name 'myclass'
> style
> outlinecolor 0 0 255
> color 0 255 0
> offset 20 20
> end
> style
> outlinecolor 255 0 0
> color 204 204 204
> offset 10 10
> end
> style
> outlinecolor 0 0 0
> color 255 255 204
> end
> end
> Gives two outlines of the polygon - one blue, one red - and one filled
> polygon outlined in black. Setting the backgroundcolor color object
> for a style object does not seem to work at all. I have also tried to
> explicitly change color, backgroundcolor for a style object in
> php/mapscript as well with the same results.
> I did not see these in bugzilla, so I wanted to verify if I am seeing
> a real bug - have you or DM Solutions developers been successful at
> using multiple style objects for a polygon layer and seeing that
> color, backgroundcolor and outlinecolor all behave normally?
> Dan Barron
> dbarron at ddive.com
> At 11:10 AM 7/10/2003 -0400, Daniel Morissette wrote:
>> Then my previous reply was wrong... it seems that it's been done.
>> Cool! :)
>> Daniel
>> Stepan Kafka wrote:
>> > There is possibility to CREATE shadows with offset parameter in the
>> current
>> > version of Mapserver, eg.:
>> > CLASS
>> > STYLE
>> > COLOR 0 0 0
>> > OFFSET 3 3
>> > END
>> > STYLE
>> > COLOR 255 0 0
>> > END
>> > END
>> > Stepan Kafka
>> > > -----Pùvodní zpráva-----
>> > > Od: mapserver-users-admin at lists.gis.umn.edu
>> > > [mailto:mapserver-users-admin at lists.gis.umn.edu]za u~ivatele Dan
>> Barron
>> > > Odesláno: 10. èervence 2003 0:32
>> > > Komu: Daniel Morissette
>> > > Kopie: Steve Lime; mapserver-users at lists.gis.umn.edu
>> > > Pøedmìt: Re: [Mapserver-users] map drop shadow effect
>> > > OK Thanks.
>> > > After re-reading Steve's reply to the original post it sounded like
>> > > Polygons were in the works but not working as yet - bad
>> assumption on my
>> > > part. So has this popped onto the wish list or future
>> > > development radar at
>> > > all?
>> > > Dan
>> > > At 05:59 PM 7/9/2003 -0400, Daniel Morissette wrote:
>> > > >Dan Barron wrote:
>> > > > > Follow-up to an old post.
>> > > > > In the latest version of MapServer has there been any further
>> > > developments
>> > > > > in creating drop shadow effects for polygons?
>> > > >I'm not aware of any developments in that direction.
>> > > > Daniel Morissette morissette at dmsolutions.ca
>> > > > DM Solutions Group http://www.dmsolutions.ca/
>> > > >_______________________________________________
>> > > >Mapserver-users mailing list
>> > > >Mapserver-users at lists.gis.umn.edu
>> > > >http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
>> > > Príchozí zpráva neobsahuje viry.
>> > > Zkontrolováno antivirovým systémem AVG (http://www.grisoft.cz).
>> > > Verze: 6.0.497 / Virová báze: 296 - datum vydání: 4.7.2003
>> > Odchozí zpráva neobsahuje viry.
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
More information about the MapServer-users mailing list
