Orthophoto basics WAS: [Mapserver-users] Raster geotiff turns
background yellow
Frank Warmerdam
warmerdam at pobox.com
Tue Jul 15 15:27:36 EDT 2003
Charlton Purvis wrote:
>> MAP
> IMAGETYPE jpeg
> OUTPUTFORMAT
> NAME jpeg
> DRIVER "GD/JPEG"
> MIMETYPE "image/jpeg"
> IMAGEMODE RGBA
> EXTENSION "jpg"
> END
Charlton,
As noted by others for GD 2.0.x you should get something at least 2.0.11 or
later. Earlier versions have serious problems with alpha blending a few
other things.
I would also note that JPEG does not support IMAGEMODE RGBA only RGB. I am
not sure what will happen if you get this wrong. Likely nothing terrible,
just that the alpha is lost when writing out to the JPEG file, but it might
is possible it could cause other problems.
However, I am doubtful whether the GD version or the IMAGEMODE thing are
your problem if you are getting other layers OK with this OUTPUTFORMAT
configuration.
Have you tried this map with "shp2img" and with debugging all turned on? Do
you get any messages?
eg.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
