Mapscript Bug? (was Re: [Mapserver-users] map drop shadow
effect)
Dan Barron
dbarron at ddive.com
Tue Jul 15 19:03:10 EDT 2003
--=====================_8815390==_
Content-Type: multipart/alternative;
boundary="=====================_8815390==.ALT"
--=====================_8815390==.ALT
Content-Type: text/plain; charset="iso-8859-1"; format=flowed
Content-Transfer-Encoding: quoted-printable
An additional observation today on this bug. The Polygons for all styles=20
are being filled it is just the fill or color component that is not being=20
offset as requested in the mapfile or via mapscript. Here are two map file=
=20
layer defs and the associated output image:
LAYER
name country
type POLYGON
status on
data 'country'
transparency 50
class
name 'country'
style
outlinecolor 255 0 0
color 255 255 51
end
end
END
LAYER
name countrytest
type POLYGON
status on
data 'country'
class
name 'country'
style
offset 20 20
color 255 0 0
outlinecolor 0 0 0
end
end
END
Looking at the image you will see that both styles fill the polygon - 1st=20
layer style color yellow + 1st layer transparency 50 + second style color=20
red =3D the orange fill seen.
Dan
At 02:55 PM 7/15/2003 -0400, Yewondwossen Assefa wrote:
>I am gettting the same relult with a multiple styles and the shadow=20
>effect. I have entered a Bug 346 on this.
>Stephen, did this work for you ?
>Later,
>Dan Barron wrote:
>>Hi Dan,
>>Since DM Solutions is the keeper of PHP/Mapscript, I thought I'd pass=20
>>this along.
>>In trying to use the STYLES with v4.0b2 PHP/Mapscript and SHP files to=20
>>achieve a drop shadow effect, only the final STYLE COLOR actually fills=20
>>within the polygon. So using the following:
>>class
>>name 'myclass'
>>style
>>outlinecolor 0 0 255
>>color 0 255 0
>>offset 20 20
>>end
>>style
>>color 204 204 204
>>offset 10 10
>>end
>>style
>>outlinecolor 0 0 0
>>color 255 255 204
>>end
>>end
>>Gives two outlines of the polygon - one blue, one red - and one filled=20
>>polygon outlined in black. Setting the backgroundcolor color object for a=
=20
>>style object does not seem to work at all. I have also tried to=20
>>explicitly change color, backgroundcolor for a style object in=20
>>php/mapscript as well with the same results.
>>I did not see these in bugzilla, so I wanted to verify if I am seeing a=20
>>real bug - have you or DM Solutions developers been successful at using=20
>>multiple style objects for a polygon layer and seeing that color,=20
>>backgroundcolor and outlinecolor all behave normally?
>>Dan Barron
>>At 11:10 AM 7/10/2003 -0400, Daniel Morissette wrote:
>>>Then my previous reply was wrong... it seems that it's been done.
>>>Cool! :)
>>>Daniel
>>>Stepan Kafka wrote:
>>> > There is possibility to CREATE shadows with offset parameter in the=20
>>> current
>>> > version of Mapserver, eg.:
>>> > CLASS
>>> > STYLE
>>> > COLOR 0 0 0
>>> > OFFSET 3 3
>>> > END
>>> > STYLE
>>> > COLOR 255 0 0
>>> > END
>>> > END
>>> > Stepan Kafka
>>> > > -----P=F9vodn=ED zpr=E1va-----
>>> > > Od: mapserver-users-admin at lists.gis.umn.edu
>>> > > [mailto:mapserver-users-admin at lists.gis.umn.edu]za u~ivatele Dan=
Barron
>>> > > Odesl=E1no: 10. =E8ervence 2003 0:32
>>> > > Komu: Daniel Morissette
>>> > > Kopie: Steve Lime; mapserver-users at lists.gis.umn.edu
>>> > > P=F8edm=ECt: Re: [Mapserver-users] map drop shadow effect
>>> > > OK Thanks.
>>> > > After re-reading Steve's reply to the original post it sounded like
>>> > > Polygons were in the works but not working as yet - bad assumption=
=20
>>> on my
>>> > > part. So has this popped onto the wish list or future
>>> > > development radar at
>>> > > all?
>>> > > Dan
>>> > > At 05:59 PM 7/9/2003 -0400, Daniel Morissette wrote:
>>> > > >Dan Barron wrote:
>>> > > > > Follow-up to an old post.
>>> > > > > In the latest version of MapServer has there been any further
>>> > > developments
>>> > > > > in creating drop shadow effects for polygons?
>>> > > >I'm not aware of any developments in that direction.
>>> > > > Daniel Morissette morissette at dmsolutions.ca
>>> > > > DM Solutions Group http://www.dmsolutions.ca/
>>> > > >_______________________________________________
>>> > > >Mapserver-users mailing list
>>> > > >Mapserver-users at lists.gis.umn.edu
>>> > > >http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
>>> > > Pr=EDchoz=ED zpr=E1va neobsahuje viry.
>>> > > Zkontrolov=E1no antivirov=FDm syst=E9mem AVG=
(http://www.grisoft.cz).
>>> > > Verze: 6.0.497 / Virov=E1 b=E1ze: 296 - datum vyd=E1n=ED: 4.7.2003
>>> > Odchoz=ED zpr=E1va neobsahuje viry.
>>> > Zkontrolov=E1no antivirov=FDm syst=E9mem AVG (http://www.grisoft.cz).
>Assefa Yewondwossen
>Software Analyst
>Email: assefa at dmsolutions.ca
>Phone: (613) 565-5056 (ext 14)
>Fax: (613) 565-0925
Content-Type: text/html; charset="iso-8859-1"
<html>
<body>
<tt>An additional observation today on this bug. The Polygons for
all styles are being filled it is just the fill or color component that
is not being offset as requested in the mapfile or via mapscript.
Here are two map file layer defs and the associated output
image:<br><br>
LAYER<br>
name country<br>
type POLYGON<br>
status on<br>
data 'country'<br>
transparency 50<br>
class<br>
name 'country'<br>
style<br>
outlinecolor 255 0 0<br>
color 255 255 51<br>
<x-tab> </x-tab> end<br>
end<br>
END<br><br>
LAYER<br>
name countrytest<br>
type POLYGON<br>
status on<br>
data 'country'<br>
class<br>
name 'country'<br>
style<br>
offset 20 20 <br>
color 255 0 0<br>
outlinecolor 0 0 0<br>
end<br>
end<br>
END<br><br>
red =3D the orange fill seen. <br><br>
Dan<br><br>
<br>
</tt>At 02:55 PM 7/15/2003 -0400, Yewondwossen Assefa wrote:<br>
<blockquote type=3Dcite class=3Dcite cite>I am gettting the same relult with
a multiple styles and the shadow effect. I have entered a Bug 346 on
this.<br><br>
Stephen, did this work for you ?<br><br>
Later,<br><br>
<br>
Dan Barron wrote:<br><br>
<blockquote type=3Dcite class=3Dcite cite>Hi Dan,<br><br>
this along.<br><br>
within the polygon. So using the following:<br><br>
class<br>
name 'myclass'<br>
style<br>
outlinecolor 0 0 255<br>
color 0 255 0<br>
offset 20 20<br>
end<br>
style<br>
color 204 204 204<br>
offset 10 10<br>
end<br>
style<br>
color 255 255 204<br>
end<br>
end<br><br>
php/mapscript as well with the same results.<br><br>
backgroundcolor and outlinecolor all behave normally?<br><br>
Dan Barron<br>
dbarron at ddive.com<br><br>
At 11:10 AM 7/10/2003 -0400, Daniel Morissette wrote:<br><br>
<blockquote type=3Dcite class=3Dcite cite>Then my previous reply was wrong..=
it seems that it's been done.<br><br>
Cool! :)<br><br>
Daniel<br><br>
<br>
Stepan Kafka wrote:<br>
><br>
current<br>
> version of Mapserver, eg.:<br>
><br>
> CLASS<br>
> STYLE<br>
> COLOR 0 0 0<br>
> OFFSET 3 3<br>
> END<br>
> STYLE<br>
> COLOR 255 0 0<br>
> END<br>
> END<br>
><br>
> Stepan Kafka<br>
><br>
> > -----P=F9vodn=ED zpr=E1va-----<br>
> > Od: mapserver-users-admin at lists.gis.umn.edu<br>
[<a href=3D"mailto:mapserver-users-admin at lists.gis.umn.edu" eudora=3D"autour=
l">mailto:mapserver-users-admin at lists.gis.umn.edu</a>]za
u~ivatele Dan Barron<br>
> > Odesl=E1no: 10. =E8ervence 2003 0:32<br>
> > Komu: Daniel Morissette<br>
> > Kopie: Steve Lime; mapserver-users at lists.gis.umn.edu<br>
> > P=F8edm=ECt: Re: [Mapserver-users] map drop shadow effect<br>
> ><br>
> ><br>
> > OK Thanks.<br>
> ><br>
like<br>
assumption on my<br>
> > part. So has this popped onto the wish list or future<br>
> > development radar at<br>
> > all?<br>
> ><br>
> > Dan<br>
> ><br>
> > At 05:59 PM 7/9/2003 -0400, Daniel Morissette wrote:<br>
> > > ><br>
> > > > Follow-up to an old post.<br>
> > > ><br>
further<br>
> > developments<br>
> > > > in creating drop shadow effects for polygons?<br>
> > > ><br>
> > ><br>
> > >I'm not aware of any developments in that direction.<br>
> > ><br>
> > >--<br>
>------------------------------------------------------------<br>
> > > Daniel Morissette morissette at dmsolutions.ca<br>
> > > DM Solutions Group
<a href=3D"http://www.dmsolutions.ca/"=
eudora=3D"autourl">http://www.dmsolutions.ca/</a><br>
> > >_______________________________________________<br>
> > >Mapserver-users mailing list<br>
> > >Mapserver-users at lists.gis.umn.edu<br>
><a href=3D"http://lists.gis.umn.edu/mailman/listinfo/mapserver-users"=
eudora=3D"autourl">http://lists.gis.umn.edu/mailman/listinfo/mapserver-user=
s</a><br>
> ><br>
s</a><br>
> ><br>
> ><br>
> > ---<br>
> > Pr=EDchoz=ED zpr=E1va neobsahuje viry.<br>
(<a href=3D"http://www.grisoft.cz/"=
eudora=3D"autourl">http://www.grisoft.cz</a>).<br>
> > Verze: 6.0.497 / Virov=E1 b=E1ze: 296 - datum vyd=E1n=ED:=20
4.7.2003<br>
> ><br>
> ---<br>
> Odchoz=ED zpr=E1va neobsahuje viry.<br>
> Verze: 6.0.497 / Virov=E1 b=E1ze: 296 - datum vyd=E1n=ED: 4.7.2003<br>
><br>
s</a></blockquote><br><br>
<br>
</blockquote><br>
-- <br>
----------------------------------------------------------------<br>
Assefa
Yewondwossen
<br>
Software Analyst <br><br>
Email: assefa at dmsolutions.ca <br>
eudora=3D"autourl">http://www.dmsolutions.ca/</a><br><br>
Phone: (613) 565-5056 (ext 14)<br>
Fax: (613) 565-0925<br>
----------------------------------------------------------------<br><br>
<br><br>
<br><br>
s</a></blockquote></body>
</html>
--=====================_8815390==.ALT--
Content-Type: image/png; name="105830979432161.png";
x-mac-type="504E4766"; x-mac-creator="6D646F73"
Content-Transfer-Encoding: base64
Content-Disposition: attachment; filename="105830979432161.png"
iVBORw0KGgoAAAANSUhEUgAAAlgAAAEsCAMAAAFf5A0yAAAAS1BMVEX////MDAyyYiJ/TylMLCzl
BgaZWSZ/Hx9MPC9mRizldRzMzMxmZmaysrLl5eV/f39MTEyZmZkzMzN/fxl/AAD/fxn/f38AAAD/
AABj4QpkAAAAAXRSTlMAQObYZgAAIABJREFUeJztXQu7rKiOZaZvzz3d+1W7FMn//6VTvN8IqKgU
6+s+u8pSxLgIIYSAkAYG5AC7B1bwjZ6vfz9ef/HPH/R8PvlhcMspLdc836mlV/YaiFUwVh/A/qW0
NKzKwr4cC7Fg8cQYy0Jr6sYxYUx4SRgIUHFtqB6rzsKqRVQdq8uil9J/CZcYQQQQrivPvAoILw3Y
Q1cUZwlISp6XFmgkKyDY4hahH6GyYiYNdD1mJFpIIUlI9II6thHCrmTPB4A2EU1UA1QTqGWZAicD
bQv1lOUAQSxGh41lYRubmibFZJZWqTRwCHU1CxZVKbJIWZXqYr/CFlvoGyu2Z1m7C0x+BqOocpIB
dvrgek5oEFH0prJoIUR36RQu76HY4DDrF7E+iuFXol5z4Mn5vlVt65I2K22jqJoezoR76Yai0kXb
T02Fie2v6/h+Ph6I289/02+yZPssgNI3hYOfWSnl70o+NaadtPqy0V7FqmK4uijdgIEXxlUCPbyl
f51kUa+HpZLfQO5XPy1tcj1sqC8Ma2OaH2J2dNWzahrg2biBeBmlRYbO51p1KX7cBaQKINzKJLKw
0pJiVcRC91VwN3wJVLUCQmSJE3+JeKuyIsAk5aiiOhg9/1b1Lkqa8E529KSMp6leYKDqpKpXqTSM
x9tofO1uRweNzB3rtWtZNeKHiB1dUy9dMdipLFlH2FSU1f4w2laWZaASFCyq6EXoBjgFX+J+piGq
HugSr1q4vl7gmNGV44QQ9rPI9zTJj8LL8kVP+ytgacp5WKRwwmzd5u408fETPAwxiaYEzVXJ9jol
ADGjAQeaiyYY4D0HRmE4N2AvF3kC4V4286q4v/Ig0IoBNswvwOrNGQ7d5qA9uPEFVM8kKsR8r/vp
jKKKYeOj6r+1//uMWnGvGtFTKrKaTrdE5NFm9TIpzqxz9uYwmmjrJfNrBAYLn0HYaHZUVEx9VkP7
2Jl2zY4lHkhCOfC8O1JodAzVjHRAXTJUDiD/I8S+OSZqJBYQ8REg9qxRYhAoTsNsco8cr9mEPg/d
xhTaFPi9PV4v0m6AZr9wRifA28LiuM/BsbWbVwzsQdJEySRkVzfDvkuldH2skX1DjRoAXkPj+lhv
borNRDWu2KqQrEq3qpUhqoSYDLRhvtP4LlOv0lq1IlhptRoZEqVvsU2tWL0025VVFast//V4grH7
T6/6+N4c8N/w4dVZBZOILbQkr3Z0JK2BxkwZPeTK2fsLM0mW3Dm3hg2VIZfhze0f9QpJ5L5KUI3t
suTbafz2HIRFZVOqvRW7dscGg7UaJOq0JNSL0bEEftiRHA/vA8LPmKNZOUldevKvC9prTuObV+nr
g3rBRc1oJAj+j/jJqZaoT0QuOOqgLsTPR+QGMXGlb3t0VxzVIsHj6tjRBkLUF2WYL0YAmlLPx7vl
3fKFgYf1GEH8lU5LErzs8JphEXuAwaqAZ7C0VohyFgOcg817M+fBMQ8MMowPY7KgmZD8fpV1qS9y
yVkdyxY+sTejBrD8TKfopaUORPU/Z8ytmLKxhzOvhspJdtaUzwTcALGmAppP1vn1ksFcZpiFs4Kj
+YiQ1cOeihKTAW5MNPvT7I1y+UiNT4eAM9dmWNqW9O9MOwVe66VdvYzZQxGGyP8SwuK8XirEisxp
IbMFG+5/WbsF/BeWPcrfCewudr3AsytUzaxw+aMtH/dAYlCKZczQ4c2TP/5kVI4EhlPEnk88tkoc
wtem6sT+eCIjeu6/iSuX3WNhHQ7vB+m/xJMXYCROQcpOa1I1dnN5gISUFFu/Qfxwk+PrhUQTi9+X
91WN5CXveNDJtYjfxDJvphNsREKosUpYO1SU51MugmgTRuIU1L5+xv2I3eOwLvScSikAaEMMyWpZ
ERBnVI1VAezuuVVXHYc9OTAb46NTq2XVapq4pXFytbBdK8EvEatxXsCBJSdvivikSrmimqw/lYs5
96zVFKreKY0xOQNrCqwhUlWyq9buLRbNVDerVdm8frv51aJqtXuNxi2zglnaVysPTWoFKFtOAm3U
V7G0Gg0ziuvVpFZXrVZxvZpVq4TxzeYWCoXVbGqhsF4NauRVC0A6R9LxW02rZalK5qI5vVbgZVmg
x06rVXLKIlattQj7o1GycPbo7pIoJypx2mn6ukNfMbG/FFTrsDk/QnxvMwsNZCsMVu9KJ5OaUYyl
osu6He3HDq+ORmZfg890VSTQMPKUI6BtHYBYCBwLaTwGWJjLsbu2m02wwO6akMQ5tVrpW06SVRq2
8XFCgGdA21ou39PCKfzbghbWBXXWmUiK47KyumzFCqGGEGV2h6uN3GGIB6OHSofenoLPz8fn68/3
44k+H+jj8fF4oCf6edCIYvHxm379988T0A/6g//5z+v014Hvxw96Pn4fX4nC3dWla9Z64Oe9wpF3
wdfnJ33cz5dYXkL7QQ+Rwfr1z5N9/EUs68cnPNm/+B8Mj9fB19Ffds4zVfqG6DI9wrwSt4oAxbWv
fFgVp9zQk787yq0iyG1JgZLvzCuNlZgB8wmBBckG5GUVwFudod9No+zk+IltcCIVAzCVjQyIcIPg
DABYsYPBsu8pK/2eE/U3lBus6WnlyQmfojl2T3khHR8ch35++Sl4updMxr3R/WWVU3UtAr7Wxh8b
avMgw0q4sayyoMOFaVz2bLh4kY5X17LC2n8kT4ykkOsSQgqTNYKnf7iI3LmNl6InhPWMNNpX++fK
k0/fE5xbk+miZX9wAHo06Da595CV1ksqd/SKsKTFvtgzf0ZxPUvO2EfEmr5wRcWPso1kAE9hiXgG
WXeCk+3wJQQCoKz/YBskiy0MDbWUSOkyKThotKSpEbCO2TBz0C1sCoWtLpkmfSo9NM1yjoPML6VP
5okv4iBs8QsYodK6czjjyY6A7W/x7S0wT319maPhsoS5vaKZmDoRGYgucc26ZKyZzfNsY1Yb9ABG
biFP+Sncs0PAs/HiozN2lk3lr6rSv1grps1c58o4Q3KN1k0hPDF6NU0A604NcQID6z4mkd7fyXF0
Y0FxGAkOjU4QBXMmO7k9CXd1mJImYvWh2QynpoETR0I9+uxaDfxnYyFhRhpUgqZp0TqLL4vk7G0b
o3AYAo5P4cnhFhQbGgqPDkw522W8zAvV9uTIM8Sue8ovrrIMD/TLuKroyfjyW040McRi7TalJS8P
yxNjQSWCqlLPRolmcp37CoqDJL8WQ2xbcXeprMCbx4n/ziBUmgvh2BAakShTrGPpSSOLyN1dZQOi
f4we1OlFVazA7dtbHYj92Y01dnV/4JAu5R1EyF05wPbF8+LYA8KKjm3I2YmH2kAPlF1hOScakx7v
IJcAcBLcv8XP1KJcd2z0B4DUcl69GttPQrYyWd4hsN/uogQjwmLXDfH9hBXlk7us0P3OGuL7iCvB
o0AeCe+Mu7uxcgG+jZABf++PztU8xGYhpuTuHkGBMZz9QIchzabctc9OE+2xNQbz7eyCDhtihY7K
xjV2xdoRsecsTT0QRsukesfDJ9bk6ept4jr7CXeEvyPZ7uiHXeU7SJUL6+xn3A/OtOsQVhIHiciV
VidtUcbpHiusXsTlxXXsDHWjHsR1sLDOXEh/AIS0hrCykPu8S7YDNSSrTqQV0fGRTt9d9JMtqz6E
JZ8s18UizygTVRcw7NLch+MRMqvUcorrgliIrwZABY8DfOnKirSci3JLb79l1DHQ4aTe/OqaqEqI
dQ9xRR4ocVjsa7sfrzhuIa0AVp4yJiv7aYv11eW7h7XItuAldEoa5BTYEtDrJcVpxHqJSyGcaitx
vpsMYJeHU6tw5/Vz74idDQPBql5ju/Z6Kk5Nvbdun9Kyd/TTKHtauY3plXXVLiBC08vWU04KuLxS
3xFmJqZiUYXScfTaCLdBSepNaFUPaVOFLNn+uVXyhMbkZbCMIS0b4OVzfBtaMWx6zNzVxwNKUkNW
eXijgOdabBZRzPG4el2gnJV8wYFPN4NOLVT0CIsjGb+7caGlKzNDXUlmv49f+8Aj+JGK6g9bTVNS
edfCW03fYeU35V8uNEb7+n58sNzKn+j1CT0+0fMloufji6alph95vukv+Ocf/PxFf+N//3zwgzxB
9c8jVbrbclcy/wYkeanUYs8nYqmkv6mEnkxYiCehpsJiH7/Z178xPNHXAz//qCvSKagpCvWc02ZF
BsXrCOvz4/FBU5x/faAXWdD3hxKW+CiTc3/Rr48v/Bf+C7FTRTbvNNaVVPxSwFDXqxyHT5rZPB+l
r7q6GdEZ1+X6swVJFL/q2uT3WFyM7zHXGQRUCCs3yaifPfLurqXyZpHbEgPnXXJLngLMxQlimNoJ
PrM1rlhcwdBfF5Xt6JYggU8eLIFinmfAPt1f8x3yUiLWHO/ufyPBPGoKYG46E8yd7+Zn8vyUVrqQ
23qWsioO5nNnTOOBM6cSGPmvJmm7JLL8YaZ8Vj0WRjaQYHC/jHy4obCysISEFc3FJqUV7js6ySOT
1PGutGKnG3lRgsIihNxXaeVCc4WLI/akQlBpA473nrcV1nrFtZaXwvLCrpzsBEq/h250Y1kx5HSJ
VAIiFs/v0LADVaxb8r3lFKCJDx2OolpZ2LoCU1jBYkuDAW8Isc5LiAsZpIFgxidjQZI4DYmz70+u
VcDEEw7IBMrqD+i9USy1xTcFUd2i/IDfYi8ZGXHtHheeKi+NH7BREXfrUO2vTm9b7XNgJ5cLHbfA
WikIGBfdeZPDAhibAdjHw7IiziYD8ux2FT4VMAVbYpBY/AIUGEi/i7TEShGWQccI648Ka5bJza0Z
V/lh8Vp0VwAzV5p12NXu8jig5XVFkE05u9XdGmoR0ozMYOtIQlveT0aX+zph131tT4T443PblAjT
gMjDvqyIsL2SpSlhQXfbOZnmA9GeGnlYdADK/uTfPHtdWrQElP3leAz7gKIW3SgBm0fBSCnG+0B2
VE9w6F1Q5Ae2lQ5ekE3NjuRlPJbZaoDpM7FVmKGy2GHl8ON7hXEJMptV6jSrESeb7r2w6JWmtsFJ
x4JgTqayLafld74LERPkTPc7BCEtQUpbWP3wC+vG5oINBhfzVCZcCEd3EiS3tQoIqxd6gdxqdBVM
oDi6kzJRp4WEFbjDHeW3usmjhNBHyJhcJaHTyQI5q8hv6rFgj8Y++VP55mkyFStRfvcQxYRlGxCX
LaybhpawPp9/TElL2VjCfI14SAXd1H4pxo59YtwE0tmz2xO0BBCpQIjlwXfEYQWCJDzv/HctKyNV
mZ6Bu6ekKIjc3tCNErHPSv1on0iInS3EFdd9RYWo+wVLPf8at5iRDcFIkMTGmYhPLxE2mJyM3tAe
PN0axEiUZe0Fqf9NxOkQ1TKl3n/956h41h57EBWiT7fY9qT+wZl0JiHCERHaJXcBo1rQ3FVSMqu3
JB/gC4xCiUdxLqHiCZqn2Rb93NXGmbqVyVkcQKr/4vuEss+qKb2sz2hhwMOZhZ4SUx0iyML38txQ
frEqg7HLqLX30KoGIsToApE2GiI2SQ8I71mYqaup5tKnCqZ1IZ1ULJ+5omIuGav4IScwKw8id/bc
U3gkoUAWozXVmwBWS4wOMO8CYTKFHgGcvyUlmlhA+RpvSioBx+2yx7OATyC2p98ORV8OuQ8V5Vuw
0XYjqsqXHpt/nWbT/vc+dIK153FDaqgRxoIJrcMznu0Dve6MLHt2NRwkYiNo/qM6b57UVAU46xhn
OqGmixMfWlT+ZBBjG2lTVq4T2brIOmA7EI+v8YkIKzPiBnU5OSOwnGxccSd2CdOgCIWS2GfHFiR3
YGZlQUqLDvIIcjapdUUT9bi/QUvkoM8I0peXaoTKLxNdWPYOkH0fFUKqFSJThlGPdOdQhoIbCiLW
F2isSKt/RPe05dyy4nFMIb6nsBKiYqpMG7KWDN+i0dkAWKLSmvj2mrzNUQtW//R+gqKLmxK8cqae
7eDCc+t9BrC/DCoCcIz77jb4XUVaUPYY0Tm9l/noAoSFNAVk5Z30dsZDiFlTRE5etAMr4X3EFZDV
ZJErCV7Gu0jLGzMbwgpRyYW1zLhzhHiVvwWpioruXlivEXPQEl0RVYxcPSM2FpzWieX/fvbDHAlI
jJqzmuBk/fHdEh0hKYZMfeWc1mtLDHV/YQmUCKxHauUOAovRobCWtLA2bMTdRYC3jZIxc6m0+tNb
h8kK9xfjnVDum2UVWJl+b0Sa4TRlmwxJafWl5SOi2kFQUlwdISSo3SSFuwnx5jjKytLS6qklWk+2
J6cUzn7C/QBaWrs2vx6FZWSV3FdXmcLqZoraXYV6hLD6iX84SkSmsLpxMutmeJSwOppJPF5YXVLr
UGH1Iq5WwupCWoJaxzZDNKiVha7G0kJYh/aG/UDI6ihpnf14+wILaQ1h5eAoMXUpLN4frlKrziIz
VFYX/eGasECfWCGwM5/sCOCYtPxEdFDYaPvqCynKHvSteaXTUuc9ps5B/Ya8Suw8kDo/tHdPupAe
FLxFBcySaq1EdYjNU0qJ1YOwTIJkXsLOXI9WOrTaZyHIgxSA58FYkVaHGotiqchVu94Qa4V1k9iu
TK0iT0sbqe4T56use5AyOzONmt06pBHeNSezhJ+Ibk1a9cTalhfudCQe9Bj1fgdqFVpC9HQql4w8
+qU21g3So5c+EhF7PoSkta0msLmEluDr6tdSZhIrV5Te+sPlRbnxLsh5XZFVjkdgnmXL2y1pPuzE
0ONRIDSR35ssfAukiKopfwu32J+mKlft6hXF6l3Sau4tlp4iHYJVLH5jb+seXBUlqHle4TO7a07m
etQ9ryRWr9KKKOOyxxUqXfaq3VKLp+AHd9OrssdlFgjSu5322RKJmXSsGiAW3ymboUdRIVNaOrFr
qSkC97BE98A8iw19EruypeHLqlNmIbHx5EQtybqdGAK86ldY2zYxD2xY2q+oKBIb9awh1Dv0Laxa
yCw4nqyHuFzIbrSvLc8zUUiHsEOmS2s0ALk1Ud7ZUU8f6XhsqFG05weELX8ihtH9E6zgASP7UHcv
Ig1Bh6wnBsGtK3uQW+CN6LEFamea6qvfStTbFfMbCasW77TL0UYQ5+9AHNpreGo1boEhonyQIst/
E6wAT27hHWnnrYTnAYTs8sJbBK4Fu8R3t2SbAHxiHReEAiucifnySu6QQ6y3HyQF8fPzjb5/fowj
T/cU70D8KH+XT2eHl2MEvzqduka8tfK9aW3jN/0BYAy/A/j8+PxC3x8fn/zrzy9jzM8X+ni8Pn2w
g0/xz/N1lNPp+6mP0kt+f9Sv//0/Six4ou9XAb//xfiv/8X/81CFI+eCD3ajKmhixbb/3aQs1xal
8XM2K8Ve8fx+fCHOFP6VU+hb/v71MIjF/9ALDGLRc7/1r8+/X6wC+unjRdqX4J//ylcvSnUuiCjE
dRi59lu/WKYLrVT/g1oOvri+YOx64ePx+Hm96O+fx+Olw+i/L6X1+3iYxPri58ij9Nyfb/WrKIF+
+33QN/DvX3/+/ENVGD/Tu6CaWBRHdrXRW4K/L+XglY+vz8fn11GFR2ZMdrxB6ymGRUe4+SOVgVY4
nFiJvaM3FRr/RVn0i36ySy+/6BPKCjouOBP2N6EXHHY02PfVdx28ao+Z5sCfZiJxxD2E2cPs6ZV7
EJJRk1Wiiou5rQXWsYFWIP6XvV+BGKTxzd7TpZP1uUClAGOeT5NC8iRilzhI1gC+wCsVV9wTaU8l
Zaw2jJ4C7q7VXo8Y3iPeI9ag1uFwpyrrtZbs77xuyklCA/Hi07FH4OZKclfup5qEme2FDKXVAjaV
NnSH0QG+51WKESDBDDY3YzPUS+a2mlZihCg1hZXqQwq+fl23/9ID7sridQLmEIC71YsS0DBdaPF2
UKstNkbxhCdyvICdwkXjxsUxdZUAkYlK7IMDTUECn8oQnH52J+4KCrd266yYfzTWqIyh4XnYTiyb
ReAdg6Kl44vVv8ZjJhJmu6eE32Ix1OWwR1i5xSxwDoE26ZL38DOaBkJgda3DjgbnJPVn8Ko9dnCT
WjErLFEMxaL7McmChI99hVc2s3LHepxTg1W3hmVyCxYsMiEY4r4FT3mokd4qrwxiKQWY5szCxw2D
WDfHS2tNZqJbZW2xSUPzTP1l4XYU6BlB4XGFUNZ9MQxwlJ7+avsjaNlbcpMMXAUgaMX3T55S+zQR
dYXQTcJp5ZPJ5ZbUP9Lhb8xgO7OJzHE/Qmh6ANiZuSfTpxn0KpVskyUc+IRfZw0XXB2pCx+86gO8
NzSYZfZgJuS3fGaBMRCcReCPGgz46b95be6/c8OABMiuUDOLv9qglbXEmeQrLIkZh9WgX5VBqo4A
hq6iJDMGc8j/uL4zVpxYq4O9ILOocnvLtG63h7cVqUprH/DyZ/LK6NFYMljeu858ejrR3Tm/GDS+
wZ4qAw48Zk1Cb0Wmj1bJZblGdaQyN+hK6LESNThwdQA2LS2mtSiXTIcWsc/OpBUi9tkVW3zE4yV4
bE55iQPNoF6e4S6d0cxD0r1siC6xbEq6UzlW3ESxT52gOaKwlsSM98BVIN+RpgiP1JvFW7MW5jjE
mszL6JXiXP7HDSJcnYi2/PREeO4X4Ka9nHnCPoaJf02Aq7IEEebwQI0Rjl0zKxON02vGfql8+aD8
YIXJODORM8ymN+vFqRmmWa+vZMejTg8Y9LoewLPhhYpJBDgII0xN8WDPEDJNd3vaiJheV+nlgJcV
BsaSD675Fu6U53rJjgBziTXU1xXBXVpWtyZ/SvRgplc+kmlNaCxzUGjFMFCCzi6DRR9M/5+ZMory
ySeWYFedGAZ2h9sfBp2lLuQ8YvQ9qhWNRGeKyI2N4efpotPsikVYDJwP2xEvTZ3kJSuRoZpNc0Rh
JQt3T3yNBoElHshk1rrmGjEVjWAEPeiuMKMvjBcnYh0ImEQVXgw+4EysWIyEcy0L+PSKKbQEcfhc
QPoRBvYB2IEOEikCxX8TvArNaRPFroLK2XaYw6wIsYK8MQaYg1et8GrEM7hmUyoKPkEN8NfsR+JT
s2HMNTn2+uR61QL9oR5jDlKdABmhBzp4SnRZhcQK/ByKmyium6iRyaxpNsI0UuwSkdTDKXEGfLe5
itSbZ9cqKSJW6ltB/bhbXs75TIGeMGDiDwV1AZDFSW7MMMM8q6/6XO5xkv2lU1Doi/K7r405VfCp
ccxI1QWz8L2GTaxJ0Wtw6jJgk33e24pOOfNLiMzEEEvT5pruIWaZ40YkFuFbM0BiOpJ+fPFcaqYA
s4zOsSK2YuAoyME9U0/sX2ccZhphwasjmdaMmcKgygompDS1FqMc3/lbW+J+3exmMJbuXwbumyAo
OFvHpo5NW1ikNPULBDFMNNVVzciQueTpnWdQ6xpBEgorS50XbUV1DXJdBKvG9sLIohyNQoeBtMLk
9DFS2k2x6cUK+l+1j3JRUT186ijQRQeYtTpb4C+zHTgGRQ4CmXZNz/DxTlQfEMRaeGDDbqP+Wbsb
vBWSFrNWcoARMojVCiTwKQ+Lr4y4zQ34kJEaWew7hgIUY/2hNWYYaAPhHS1syaFsuq+yZtk7HoF4
120n2bGHAi33PB0IgMh9BPIvAY9ax078JqaMVIpU2Vtqp4jM3HRcvQYSiKmDozbOqEKWSajjxI6u
zkAGHGXlbIJyCXoBnnO7tfMrO2AgJ2P7XihfAk2dpnPuYGMw63pQIXre1ODOW0oVLkylA4MZRVSW
X7FBrUsjtkWOvUwwxrbwcZWWUi//ovM3YPwUAOUVTRIgb6b6aLeW9R6UgRMhYhKQYXwRIoaUSHqM
CAoMMaXCgzkY1y4JFsMy0ylpPaET589gVgdQHFIHIl4LoWaipPKmbBy4oaFWtE04zgI5BBy4LeJd
IkIydjVBqpTBFY45jnXCRVNVAxeHE1pFoSbvyCqtcomVO10UNrsG7gqj8xGe8Nnc1LeqG3Quzh1J
Gn3yFdxwA7vAytonjiXSM6zRxZoNTBr5QQxbqxO4WY5EIsl6YoW2zKCHx34XbwR3q9+cvB/stDnR
Y/k5jqT9Npj1JijZjsAjC4lMLIUKhUGst0IVseR6nGkSJpn2wqooeJ9YZnz9QK8QYfCQ3fUFeKU5
IyHM7gixRqhV9+ABpZ55lcWq8GEzuj1cqlpQOJjVK2TqyLpuMPYDrDhWp7xEXwM3RgGjpuRXh1o0
nUSiJGfJzkB3yCWWSLigF8ivnZ/+MSeZ6sBtkdsDGia63pksRZ007aykusO33h9yaeV8E/li6omF
J2/ienCrHyQnAC0elXBGnZbBO4Nbg1i9II9WuTQqu9b4YdhanUBtM7GVHLnXhwrwEy8NYt0YRa6q
if+/Ykrll5U8sJISZOCSyOzzvDc/+ebVBpiaK1AqVOxwN3Amajzqelp5T6Q9YENp3QdL3TxN7NVv
R3RjFIphZt0CUDWprBhQf2k9Rmd4A0DZ0M/Czj1gNoClqTxbcgNp1Kurk2jF7z2VrrUYaIy7qSsF
GP3hlVHJq9NphYcRf2kU8moKbnJzHiC58fXAecgn1oXoZGKorYtijVlX0k9hwFhqcUkkmXV5VlGM
SZ7rAXDUPXopW2oFg1kXA7A9fn1mTXtOKjfAMLQuhzCvbqWusCDWGB5eC+GtTe+FEVx6RaS2Nr0J
BrGuiFBXeDuMVa3XQ3rj6JvAXMUzyHUZ2Ny6ObGG2roOHKV1Q2Y5MTSDWhfB7Znlbdc5qHUNGMza
d81NGwSC/gazLgFNrIm5R+/FLMD+Ew1iXQJmX3g7XgWjlAexrgHLyroZrwaxrow7M2sQ68qwesO6
96tRt16/EpH1OoNaF4E1Mix8teHdn8UWKNULFzNvHnmeQayLoNT/XrBm9EBmhUaEHINYF0EBsYq3
pw/sv7QL2VL1GMS6BtwXHWdW3RpkcIrYgVhxbUUxiHUBhANJd6QVcve53ENhJasyeHUFROJIaVD8
Ik5ZNidLAIMN/hZyg1d9wnUPwAEZXUCzYW3PzAxaJfvBvYk1sttsgO4OuXG+f6MHzga2hANtZNbK
m9678sXjlYE4jupjZw1GAAACYklEQVROhNtrU3e49pp3rztTt4Nc+2D72yEabpQUrO4hXU+rQ9rE
oNZ+2PB+Iuv8xI44+rcaZp3CK24rDGbtgtIXVBC5uYVZje0rDdjgbhkwUPCKihciy9OtIMMdiHVs
WDIwH8xg1zZU6J+K8gWzCva2OHMih8+qD2bVo0AFVb9Ng1n78KqBY1T4eWUllqG+ChF5RYTozmZ7
r8MLIMyF5u7I5M8vVld6R5gzU2ImbDCrEC5vyAEZXQiSbFhm8vofDF4hY4vz7MKOhm8SDl5VQBPp
qCxBoljJWeLNShZMUh5PLGvmi606GbS6NgSxNlHjaF65jhGY0Vgbew8ID33dtTvXJYTFji/iOSoH
tW6DmjfV7O2qvdJYJ+hPVQ1cGBVvqt3LNXnFbzyIdRewN/Xqdhbj2ErgyoEv154iBItW/NbUB3Pc
/Qf2A31NgRUYK1ccBO6sWsREIfgVGd3hfcB1Vj6xDp14Xq3AYNWNQHWAzSzwhoxNHe2DV90AptnY
IwOkL5X/2KLzgRx1NYh1P6j3OtlLO9pYNEsmrQav7gimNFaW5BxyX5NU8QHpINWd0Xw+zl6/C5Ca
BR97rQxkYLHNqsy4isGtgSS8rF65unLw6uZw+p1dNYWfwCJtWxn3Hry6O/w3uNc7BeQnRkmMGXjw
mHSsDWLdH+473I1YgRmkrKRug1SdgCS+1YPnTs0zrxo7/weagBysLlR63mgFhrrqE4bJfMIgf9Cq
Z2wPj6+8r1WHQasu0fy12kQyl1cODFTB8Z0NRg3sAY9Gg1YDm+FbUsO2GtiMUK83aDWwGQHlFOfV
/wOnn+cekgT76AAAAABJRU5ErkJggg==
--=====================_8815390==_--
