[Mapserver-users] ASP, Java, mapscript and other fun stuff
Van Ulden, Joost jvanulde at nrcan.gc.ca
Tue Jul 15 18:14:33 PDT 2003
I don't understand the reluctance to install php on an IIS machine.  In
reality, from both a developers and a administrators point of view, PHP is
both more secure and easier to administer than IIS.  We are running
PHP/Mapscript and IIS on several machines without any problems.  I would
suggest that you confer with your "superior" before reinventing the wheel.
I would be happy to share my experience further.
Regards,
Joost
-----Original Message-----
From: Dean Taylor [mailto:dtaylor at karjeni.com.au]
Sent: Tuesday, July 01, 2003 6:29 PM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] ASP, Java, mapscript and other fun stuff
Hello all,
I apologise if this has been covered before but I have searched the archives
and can not find anything recent.
Basically what I want to do (or more accurately what my boss wants to do) is
get a Mapscript application working with IIS without resorting to having to
install PHP or perl and preferably without needing a java engine installed
either.
So -
Is there a COM component around that can be used within ASP. the archives
suggest a demand for, and some work being completed towards an ActiveX
component bit this seems to have petered out. (What happened?)
Does anybody have any compiled JAVA components to work on windows? Has
anybody successfully compiled them using Borland C++ (Command Line)? Am I
setting myself up for a fall suggesting that I will have a go at creating
them. (I am not a C/C++ Programmer but have done a reasonable amount of
programming in other languages).
Any advice will be appreciated.
Thanks
Dean Taylor
Data Systems Engineer
Karjeni Pty Ltd
www.karjeni.com.au
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
More information about the MapServer-users mailing list
