[Mapserver-users] msPOSTGISLayerWhichShapes() error
Bill Wheaton gisgeek at nc.rr.com
Tue Jul 15 18:52:53 PDT 2003
Hello folks--
I have a problem that I think is related to mapserver versions, but I'd
like to know for sure or see if anyone thinks it might be something
else.
I'm developing on MS 3.6.4 (w/ PHP/Mapscript) and postgreSQL 0.7.3 on
Macos X .  I moved my site to an ISP (pghoster) which is running MS
3.6.3.  I know that I shouldn't assume that anything is backwards
compatible, but...
My code works fine on my development system, but I get this error on
pghoster (the ISP):
Warning :  MapServer Error in msPOSTGISLayerWhichShapes():
prep_DB:Error executing POSTGIS  DECLARE statement (0.6 failed -
retried 0.5 and it failed too).  DECLARE mycursor BINARY CURSOR FOR
SELECT
ship_name::text,asbinary(force_collection(force_2d(the_ln_geom)),'NDR'),
OID::text from ship_voy using UNIQUE oid WHERE (voyage_id > 0) and
(the_ln_geom && setSRID( 'BOX3D(-180 -90,180 90)'::BOX3D,4008) )  in
/home/virtual/site170/fst/var/www/html/mapping.gis on line 728
My map file looks like this:
LAYER
     CONNECTIONTYPE postgis
     NAME "voyages"
     CONNECTION "user=xxxx password=xxxx dbname=xxxx host=xxxx"
     DATA "the_ln_geom from ship_voy USING UNIQUE oid USING SRID=4008"
     STATUS OFF
     TEMPLATE ""
     TYPE LINE
     LABELITEM "ship_name"
etc...
And my PHP/Mapscript code looks like this:
     $sql_map= ("voyage_id > 0");
     $selected_layer = $map->getlayerbyname(voyages);
     $selected_layer->setFilter("($sql_map)");
     $selected_layer->set(status, MS_ON);
Also, I had some trouble moving the database to the ISP and handling
the geometry columns, etc., but I think that I finally worked that
out-- but maybe not?
Before I ask the ISP about upgrading their version of MS to 3.6.4 (or
greater?), I just wanted to try to confirm that that was the problem.
Could it be something else??
Any information is greatly appreciated.
Bill.
More information about the MapServer-users mailing list
